Igniter 2 regulator issue
Old Jul 17, 2014 | 11:31 AM
mattgthomas1965ford's Avatar
mattgthomas1965ford
So I have a 1965 ford f100 with a 240 i6 I recently upgrade to an igniter 2 electronic ignition and noticed the regulator started to make a clicking sound. So my question is: how can I bypass the regulator? Or is there a modern regulator I could swap? Also, I found an alternator with an internal regulator, will that work?
Old Jul 17, 2014 | 03:04 PM
shortwide's Avatar
shortwide
I think the superior regulators from the later model F100's will swap in.
Help me out here NumberDummy.
Old Jul 17, 2014 | 03:30 PM
Tedster9's Avatar
Tedster9
Your ignition shouldn't have anything to do with voltage regulator as such. Possible ground issue?
Old Jul 18, 2014 | 12:12 AM
mattgthomas1965ford
Thanks for the help
Everything functioned normally when I had points. I should mention I upgraded the coil when I did the ignition. The problems have started with the ign /coil upgrade. How would I check for a ground problem?
Old Jul 18, 2014 | 10:22 PM
Tedster9's Avatar
Tedster9
I'd try a different regulator?
Sent from my iPhone using IB AutoGroup
Old Jul 18, 2014 | 11:06 PM
mattgthomas1965ford
Any ideas about which one to buy? Should I go with a more modern swap since I have an upgraded ignition?
carprojects
Aug 26, 2020 04:27 PM
daveengelson
Feb 22, 2017 02:10 PM
Gwencon
Apr 14, 2016 08:57 PM
ckleine
Aug 17, 2014 08:53 PM
