Vent window replacement glass
Old Apr 30, 2019 | 09:33 AM
4EyedTurd's Avatar
4EyedTurd
I’ve found another vent window for my 64 but the locking handle is broken off of the new one. I’m confident I could pull the good glass out of the broken frame but I don’t want to tear up the good frame. Has anyone done it successfully?
Old Apr 30, 2019 | 02:04 PM
SixtyFour's Avatar
SixtyFour
I believe the glass is 'glass taped' into the frame. I'm sure some heat and or chemicals could soften the tape to remove the glass.
Old Apr 30, 2019 | 07:21 PM
resonateur's Avatar
resonateur
...Acetone, lacquer thinner, wax and grease remover.....heat gun, but not at the same time as the former!! Watch not to apply too much heat to the glass with the gun, or you'll crack it. Also a small blade to scrape out some of the glass setting tape will get the solvent started.
Old May 1, 2019 | 03:04 PM
4EyedTurd's Avatar
4EyedTurd
Thanks, I’ll give it a shot
scottlathrop
Aug 2, 2015 08:04 PM
f100today
Dec 25, 2013 08:35 PM
ungerp
Jan 2, 2013 03:54 PM
littlecobra1977
Nov 7, 2011 08:54 PM
3414
Apr 16, 2011 12:20 AM
