Fe Block thickness
Old Jul 11, 2014 | 06:42 AM
Super Dude E's Avatar
Super Dude E
Fe Block thickness
Is there a rule of thumb that has been learned from past sonic testing that can be shared. Pickup truck 360 blocks vs street car 390 blocks ect. Does a certain model seem to have more core shift than another? Thanks
Old Jul 11, 2014 | 07:32 AM
6t6merc's Avatar
6t6merc
The rule of thumb is that the 360 and '65 up 390 (and the short-lived 410) used the same block. The 352 is a different story. It is presumed by many, including me, that the 4.00" bore 352 has thicker cylinders and is essentially an "underbored" 390, but others disagree.
Eric
Old Jul 11, 2014 | 11:13 AM
moonley's Avatar
moonley
Its not as simple as car vs. truck. Google search "FE drill bit test" or read up in the FE forum, here is an example: https://www.ford-trucks.com/forums/6...st-rehash.html
Old Jul 11, 2014 | 11:55 AM
orich's Avatar
orich
Gees to much here say and not really enough true input per facts.
Block shift from 332,352,360,361,390,391,406,,427,428' not one person has the correct answers. Best at guessing ball part answers. as the blocks were made in many places along with the replacement service mirror 105 blocks as being thicker. As these have the main bearing web block enforcements. It's really best to sonic test each block before boring it..
But back in 62, I had a 1961 390 gt block punched out to 4.1/8" ran 12.5-1 pistons with milled heads with the thin steel gaskets with a high compression of 275Lbs psi and never had any over heating troubles in my 55 ford 2dr cp. with stock 55 rad.
Orich
Old Jul 11, 2014 | 12:50 PM
Super Dude E
Lots of good stuff here. I'm an old mopar drag racer learning to speak FORD.
Old Jul 11, 2014 | 04:56 PM
JEFFFAFA's Avatar
JEFFFAFA
Welcome to FTE!
Glad to hear you jumped ship. (Can't resist) To the Bright Side!!!!!
Old Jul 12, 2014 | 06:36 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 6t6merc
The rule of thumb is that the 360 and '65 up 390 use the same block. The 352 is a different story. It is presumed by many, including me, that the 4.00" bore 352 has thicker cylinders and is essentially an "underbored" 390, but others disagree.
Eric
1968/76 F100/350 360/390: The bore is the same (4.05"), the stroke is different.
Stroke: 3.50" / 390 = 3.78."
Old Apr 14, 2015 | 10:29 AM
waza30's Avatar
waza30
105 mirror block
I have a 390 with a backwards 105 stamped on the drivers side. Can anyone tell me what this is. I was told it is a 1968 with gt heads. Thanks
Old Apr 14, 2015 | 11:32 AM
orich's Avatar
orich
See my post #4
Orich
shephard199
Mar 6, 2009 02:05 PM
zrtkicks
May 12, 2008 09:10 AM
71PA_Highboy
Sep 14, 2006 05:01 PM
scottie2hottie
Aug 28, 2006 07:46 PM
tai-tanium
Jun 12, 2004 02:38 PM
