390 block
Old Jun 12, 2004 | 11:34 AM
tai-tanium's Avatar
tai-tanium
390 block
Any info on block with casting #'s D4TE?
Old Jun 12, 2004 | 11:41 AM
fordman428's Avatar
fordman428
it was a late 360/390 block that came in a truck, there pretty strong blocks, some can take a .080 overbore to accept a 428 piston.
Old Jun 12, 2004 | 12:09 PM
rvzavala's Avatar
rvzavala
You may have a 391 F.T. Good block to build from. If you do have the 391 it has the forged steel crank, thicker cyclinder walls and higher nickle content to make the block stronger. My old engine was D4tee on the block and was told by Jasper Engines it was a 391. I used it as core exchange. 625 cater, 204/214@ .50 eld per intake, 8 to 1 CR, stock head with headers. Pulled like a John Deer, ran out steam at about 4,000. New engine just screams Jasper Class II 390.
Old Jun 12, 2004 | 02:38 PM
baddad457's Avatar
baddad457
Better do a sonic test of the walls for overbore capacity or at least the drill bit test ( I use feeler gauges) to see how thick the walls are. Not all the so called truck blocks have thick walls.
