390 safe bore?
Old Aug 28, 2006 | 11:24 AM
scottie2hottie's Avatar
scottie2hottie
390 safe bore?
Can a 390 (105 cast on front) be safely bored to a 4.23 bore.......Supposedly 427s and 390s have the same bore spacing so this SHOULD be doable...on paper. Any experienced folks know this one?
Old Aug 28, 2006 | 11:40 AM
hoxiii's Avatar
hoxiii
Same bore spacing, but the 427 is actually a totally different casting from all other FE blocks. There is no way that you're going to get any 390 to bore out .180". Now, if you were to take the block to a really good machine shop they'd be able to sonic check the block and let you know the max safe overbore.
If you're REALLY willing to throw some money at it, ask them if they'd be able to bore and sleeve the block to 427 bore.
Justin
Old Aug 28, 2006 | 04:09 PM
Bear 45/70's Avatar
Bear 45/70
I was able to go .080" once on a 390 to make a 406 (4.13") out of it. But that was a 390 HP block from the early '60s. Otherwise, unless you check the casting thinkness and sonic test, I wouldn't try it. The 428 blocks (4.13") were 105 blocks so it would be worth checking though.
Old Aug 28, 2006 | 07:46 PM
rusty70f100's Avatar
rusty70f100
Get your block sonic checked. That's the only way you'll know for sure.
I did the drill bit test on a couple "mirror 105" blocks I've got sitting out in the garage. I then calculated that, assuming absolutely no core shift, they could be safely bored to 4.23". But what are the chances of that? Not too high...
Tuttle69
May 23, 2014 02:32 PM
wagonerkl
Sep 1, 2010 12:03 AM
shephard199
Mar 6, 2009 02:05 PM
71and72F100s
13
Jan 5, 2003 03:20 AM
Dave
Nov 10, 1999 01:57 AM
