Sponsored by: Real Truck
Power window issue
Old Jul 4, 2014 | 05:22 PM
blueray's Avatar
blueray
Power window issue
Done a search and nothing quite looks right.
03 F250. Passenger window is stuck up. When I have the door panel off, I can feel the motor trying to move up. Won't go down at all. When I connect test light to the plug, it lights up correctly for both up and down. Thought maybe it was the motor so I got a new one but it only tries to go one way. It's like the switch isn't sending the signal for the window to go down even though the plug appears to be getting the correct signal.
I took apart the driver's side switch and nothing looks crimped, bent, etc. From some reading, it sounds like possibly the regulator is bad, does that somehow send a signal back to the switch? Is there a relay or something that could be bad?
I find it odd that test light seems to work but when connected to a motor, it doesn't.
Thanks - Bryan
Old Jul 7, 2014 | 10:56 AM
MackGuy's Avatar
MackGuy
Sounds like the limiter thinks the window is already down. If the window is already all the way up, it shouldn't try to go up.
Copedawg
Mar 23, 2015 04:17 AM
Fuha
Feb 11, 2012 10:52 PM
Taboo
Jul 24, 2007 12:24 PM
Mike Earls
Electrical Systems/Wiring
Nov 12, 2005 12:24 AM
Dutch123
1978 - 1996 Big Bronco
Nov 22, 2004 09:32 PM
