PLEASE HELP
Old Jul 4, 2014 | 04:28 PM
  #31
FastTimes10's Avatar
FastTimes10
The gauges on my SCT correct
Old Jul 4, 2014 | 06:02 PM
  #32
04badford's Avatar
04badford
Originally Posted by 04badford
Your ICP needs to be 540psi Plus to start the engine , if your gauge shows less than you wont build enough pressure , you do have a OEM oil cap right?
Don't know if SCT live wire will do it , does it read live data from the PCM/ OBDII port
OH and the ICPV on the gauge will be all wacked out.
koeo -0.2 low-1.0 high-1.8 this test is taken in park no radio hvac ,or power on
Originally Posted by FastTimes10
It cranks fast like it wants to turn on but no start, I'm thinking a fuel problem
you can disconnect the wire over on the passenger side wheel well open the fuel cap on top and crank, look for bubbles and it should fill quickly if it does fill then HFCM pump is good
Old Jul 4, 2014 | 06:05 PM
  #33
04badford's Avatar
04badford
in the tech folders will be a process to do the bubble test . lets hope for no bubbles, just fast filling fuel bowl. make sure everything is plugged in ICP IPR EGR etc
Old Jul 4, 2014 | 07:35 PM
  #34
FastTimes10
Yes stock oil cap
Old Jul 5, 2014 | 06:19 AM
  #35
bismic's Avatar
bismic
It would still be helpful to see if you had FICM Sync and Cam/Crank Sync ... and I do not believe that the SCT will provide that information.
Old Jul 5, 2014 | 09:29 AM
  #36
78fordman's Avatar
78fordman
will it give FPW? If you have sync and everything else you will have a value for FPW other than 0 while cranking.
Old Jul 22, 2014 | 09:13 PM
  #37
FastTimes10
Well The AC Compressor locked up and wasent letting the belt turn on crank, so getting the whole a/c replaced all brand new.......Thanks For All The Replys And Help
BLADE35
Mar 26, 2014 08:13 PM
mcovert
Feb 11, 2014 06:19 PM
bigred66
Nov 13, 2012 03:09 PM
bkvanbek
Jan 10, 2011 06:35 AM
honda4x4nut
Feb 22, 2009 09:40 AM
