PLEASE HELP
Old Jul 2, 2014 | 11:02 PM
73fan's Avatar
73fan
Originally Posted by FastTimes10
Where is the icp/icpv located
On the 2003 your injector control pressure sensor is located on the extreme rear, on the top of the engine. Snugged tightly under the turbo and intake manifold.
Sent from Nexus 4. IB AutoGroup
Old Jul 2, 2014 | 11:05 PM
73fan's Avatar
73fan
Oh yes, and there's the injector pressure regulator (IPR) back there as well. IPR uses two pin connector, same as VGT solenoid. ICP uses three pin, as the exhaust pressure sensor.
FastTimes10's Avatar
FastTimes10
Oh ok, and how can u tell if it's bad of going bad?
Old Jul 2, 2014 | 11:06 PM
04badford's Avatar
04badford
your ICP will be under the turbo towards the back of the engine with the IPR, the ICPV ( Injector control pressure voltage) is what we look at on our scan gauge , gauges. this set of three wires gets crispy and oily then it starts to short out , Gauges will help discover if it's the ICP sensor or voltage
Old Jul 2, 2014 | 11:12 PM
73fan's Avatar
73fan
Please ignore duplicate post.
Old Jul 2, 2014 | 11:22 PM
04badford's Avatar
04badford
Your ICP needs to be 540psi Plus to start the engine , if your gauge shows less than you wont build enough pressure , you do have a OEM oil cap right?
Old Jul 2, 2014 | 11:37 PM
04badford's Avatar
04badford
OH and the ICPV on the gauge will be all wacked out.
koeo -0.2 low-1.0 high-1.8 this test is taken in park no radio hvac ,or power on
Old Jul 3, 2014 | 02:58 AM
Yahiko's Avatar
Yahiko
I am going to post the engine controls PDF BUT it's from the 06
so it most likely is not the same as the o4 but will give you an idea
on some things.
Also for some stupid reason it created the PDF with all the pages sideways
Sean
Old Jul 3, 2014 | 09:28 PM
04badford's Avatar
04badford
Thanks for the link Sean, That's what it looks like when I'm in upside down and Twisted like a pretzel LOL kidding , I wonder if this will follow the 03 diagram as well that's what the PO's truck is.
Old Jul 4, 2014 | 02:39 AM
Yahiko's Avatar
Yahiko
I tried to do the 03 diagram and the stupid data disk is not giving any love.
I may try beating on it if I have nothing to drive me crazy all day.
Sean
Old Jul 4, 2014 | 10:10 AM
FastTimes10
Back to square one, changed the fuel filters put the new starter on new alternator, crank but no start????
Old Jul 4, 2014 | 02:19 PM
FastTimes10
It cranks fast like it wants to turn on but no start, I'm thinking a fuel problem
Old Jul 4, 2014 | 02:59 PM
  #28
Yahiko's Avatar
Yahiko
Are you getting any HPOP pressure?
Sean
Old Jul 4, 2014 | 03:18 PM
  #29
FastTimes10
How would I check that, sorry I'm learning this stuff
Old Jul 4, 2014 | 03:39 PM
  #30
Yahiko's Avatar
Yahiko
Your looking for ICP pressure and IPR %.
I think that you gauge will show both.
Sean
