PLEASE HELP
Old Jun 30, 2014 | 10:06 AM
FastTimes10's Avatar
FastTimes10
PLEASE HELP
2003 f250 6.0......... i cannot figure out what the problem is.. i was driving my truck and suddenly it shuts off, so then i hooked up to my buddys truck with the jumper cables and started the truck, drove it down the road and it shut off again.....so i tow it home and check the voltage on the batterie and it was low, so i took the alternator off and took it in and it was bad..so then i charged the batteries put in a new alternator and the truck would crank and not turn over.. so i let a week go by and yesterday i got my batteries charged again and tried starting the truck and it did not even crank, i have no clue where to start now?????? ( I HAVE A SCT LIVEWIRE TUNER)
Old Jun 30, 2014 | 10:27 AM
bismic's Avatar
bismic
Load test the batteries
Check FICM voltages (Tech Folder has a thread on checking these voltages)
Get gauges so you can check for:
FICM Sync
ICP (pressure and voltage)
Old Jun 30, 2014 | 11:00 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
An alternative to gauges is the Scangauge II. Available from AutoZone and Amazon - and other places.
Old Jul 1, 2014 | 07:55 PM
FastTimes10
Load test on each battery read 12.3
Now going to test FICM
Old Jul 1, 2014 | 09:50 PM
FastTimes10
FICM 57.6 volts
Old Jul 1, 2014 | 11:22 PM
04badford's Avatar
04badford
Does the Starter engage? I would look at the ICP and pigtail connection for the stall. also check the Battery cables for corrosion even the grounds.
Old Jul 1, 2014 | 11:25 PM
FastTimes10
Started does not crank, injectors circulate when key forward
Old Jul 1, 2014 | 11:38 PM
04badford's Avatar
04badford
So no kick from the starter? have you checked the connection down there?
Old Jul 1, 2014 | 11:42 PM
Yahiko's Avatar
Yahiko
Do this on both of the wires going to the starter.
Give me a little bit and I'll post the starting system.
Sean
Old Jul 2, 2014 | 12:26 AM
Yahiko's Avatar
Yahiko
Got some more of the PDF goodies for you.
I also attached one on connector repair.
Enjoy!
Sean
EDIT : Your going to want to look at both of the starting system PDFs.
Old Jul 2, 2014 | 10:20 PM
FastTimes10
Checked starter with test light and it was bad, took it off and tested it at auto parts store and it was bad, had warranty swapped it out for new one, Ganna put it in tomorrow change my fuel filters and fire her up
Old Jul 2, 2014 | 10:25 PM
04badford's Avatar
04badford
Kinda what I thought, good luck and please keep us posted.
Old Jul 2, 2014 | 10:27 PM
FastTimes10
Thank You , and I will for sure
Old Jul 2, 2014 | 10:33 PM
04badford's Avatar
04badford
when you get that bad boy started, take a look at the ICP and ICPV your stall was not the starter .Look for oil out the connection side of the sensor and in the connection plug, there may also be a short in the pig tail this was the Issue for my truck stalling out.
Old Jul 2, 2014 | 10:56 PM
FastTimes10
Where is the icp/icpv located
