tach
Old Jun 24, 2014 | 11:34 PM
fordboyoffroad's Avatar
fordboyoffroad
tach
I was thanking this might be cool if i can get it all to work. Jest wanted some fed back on what ya thank.
Old Jun 25, 2014 | 12:47 AM
co425's Avatar
co425
Very cool if it works. The factory idiot guages suck anyway, might as well put something usefull in there.
Old Jun 25, 2014 | 12:49 AM
EP145's Avatar
EP145
Looks good! Let us know if you get it to work.
Old Jun 25, 2014 | 12:53 AM
fordboyoffroad
I Jest wish it looked more like the speedo.
Old Jun 25, 2014 | 07:05 AM
mikeo0o0o0's Avatar
mikeo0o0o0
You could send it to a gauge specialist and they could silk screen a new face on it that matches the speedometer.
There are several listed in Hemmings that do this kind of work'
And yeah, that looks great.
Old Jun 25, 2014 | 07:33 AM
fmc400's Avatar
fmc400
MSEE
Agreed, very cool. This should have been an available option back then in the first place. You should have no problem getting it to work.
Old Jun 25, 2014 | 12:13 PM
EP145's Avatar
EP145
Can you steal the speedo also so they will match?
Old Jun 25, 2014 | 04:08 PM
mikeo0o0o0's Avatar
mikeo0o0o0
What's that tach out of?
Old Jun 25, 2014 | 04:38 PM
spikinfool05's Avatar
spikinfool05
wow never thought about putting a later ford truck tach in place of those gauges. good job looks stockish almost.
Old Jun 25, 2014 | 07:42 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I bet the speedo and tack are out of an 80's ish something truck.....?
Does that speedo have a "high beam" light place and what about your R/H T/S indicator and brake caution light?
Still a cool idea, keep us posted.
Old Jun 25, 2014 | 08:38 PM
mikeo0o0o0's Avatar
mikeo0o0o0
This is an '86 dash (IIRC)
Old Jun 25, 2014 | 08:46 PM
dlburch's Avatar
dlburch
looks more like a '92-
Old Jun 25, 2014 | 11:57 PM
fordboyoffroad
The tech is out of a 95 ford truck. the 95 had a all electronic speedo and it to wide to fit in the opening some of the 78-79 trucks had a 0-85 mph with no other marking I been curious if i could calibrate the tech so it would read up to 8500 rpm.
Old Jun 26, 2014 | 09:28 AM
fmc400's Avatar
fmc400
MSEE
Not really. And by the time you updated the tach face, it's not the same tach anyway, so might as well just get an aftermarket one. Not sure why you'd need that high in one of these trucks though.
bobbytnm
20
Oct 20, 2020 05:55 PM
Tyler Scott
13
May 1, 2019 12:03 AM
Njmyers
Nov 12, 2015 08:00 AM
Magic Smoke
Oct 3, 2010 12:12 AM
shameless
38
May 8, 2009 04:17 PM
