Does anyone have a photo to post of this setup? I'd like to see what is involved with installing a coolant filter. Are there different installation options?
There are two different options for installing a coolant filter.
An aftermarket kit such as the dieselsite kit (I originally had one of those installed). https://www.ford-trucks.com/forums/1...stalled-3.html
And swapping your water pump for an IH water pump which has a place for a filter to mount on it directly.
Thanks, Alex. I replaced my water pump last year. That would've been a good time to add the coolant filter, if I'd known. I'll read through those links you provided.
If the OP doesn't mind, how essential is this mod for a daily driver, i rarely tow and don't put on many annual miles. My SCAs are in good order, is that sufficient?
Yeah Glenn I got it all figured out. It only required me to remove the pump again to tighten them with the proper angle. REALLY tight in there! lol
I now understand why everyone recommends the 45° fittings. You need them.
You will probably realize the benefit to having a coolant filter.
Maintaining SCA isn't the only concern. All 7.3 blocks were cast with sand and there is some in your engine circulating.
I will have to get a picture of the blades of the water pump I just removed to get you an idea of what this sand can do. I maintained my SCA levels as well.
Who's to say that if you followed the manual recommended flush schedule and maintained SCA perfectly that you won't have any issue, but I am not the original owner of my truck and I would much rather spend $100 on an aftermarket kit with $10 filter changes than to replace an engine block/main bearings etc
Just my .02
Damn, i hear that... I guess ill strongly consider it.... Thanks.
Corey, when I bought my dually, I got lucky to get it from a guy that did all the maintenance on it. I got most of the paper work with the truck. As soon as I got it, I tore it down and did all my mods at once and the IH water pump with filter was one of the mods. I ran this filter for about 5K, convinced me it was necessary.
