Sponsored by: Auxito
Blower stopped working
Old Jun 15, 2014 | 05:03 PM
bill57's Avatar
bill57
2003 F150 4wd with auto climate control. My blower for heat and AC completely stopped working a few weeks ago. I have checked all fuses, i replaced the relay under the dash, i replaced the blower motor control module. I supplied power to the blower motor itself and it ran fine with no noises. I ran the self test on the controller in the dash under the radio and it passed. I am not sure what else to try. Any suggestions? Thanks
Old Jun 15, 2014 | 07:53 PM
projectSHO89's Avatar
projectSHO89
Does the blower motor relay energize when the system is switched on?
Old Jun 15, 2014 | 08:31 PM
bill57's Avatar
bill57
Yes there is power to the relay when it is on
Old Jun 16, 2014 | 05:40 AM
projectSHO89
That doesn't answer the question I asked. There should be power to two pins of the relay, one for the high side of the coil, the other for the load on either the C or the NO terminal.
Does the relay energize? (IE, does it audibly 'click' when the blower is supposed to operate
Old Jun 16, 2014 | 05:04 PM
steve(ill)'s Avatar
steve(ill)
you need a good ground to complete the circuit. Check the grounds also. -- maybe try a jumper to ground
Old Jun 17, 2014 | 08:13 PM
bill57's Avatar
bill57
No it does not click at all when the blower is activated at any speed
Old Jun 17, 2014 | 09:49 PM
2Fords1Jeep's Avatar
2Fords1Jeep
What he said
Old Jun 18, 2014 | 06:46 AM
projectSHO89
You need both proper power and proper grounds, in the right places and at the correct times.
If the blower relay doesn't activate when the blower should be operating, then either it's missing its power or its ground. You'll need to verify power (HOT in RUN) to pin 86 of the and that the EATC supplies a ground to pin 85 of the relay when the blower motor is switched on. When the relay energizes, it then supplies power to the BSC module to operate the blower motor.
thingsreef
1997 - 2003 F150
Sep 8, 2018 10:43 PM
wunderin
May 8, 2009 09:27 PM
The Real TLR
Oct 28, 2008 12:11 AM
flying-pig
Apr 20, 2007 05:39 PM
ptrill
Nov 30, 2006 03:12 PM
