Has anyone ever used after market front cab mounts ? and which company would you recommend? I also noticed that on the DC website they list mounts stating 1965-1979? and they also list 1965-1967? It doesn't make any sense to me? BTW mine is a 66, also has anyone bought the replacement front fenders and or rad support? just curious how they fit and quality?
I used some from LMC and didn't like the way they fit. I guess that's what you get when you go cheap. I have heard the ones from Dennis Carpenter are good or try Flashback F100s
Thanks for the input but I'm still curious if anyone has purchased good quality replacement parts from other sources?
I bought a set of Prothane mounts , haven't got to install them yet but they look like top quality .
I believe you are talking about the bushings? im looking for more info on the front (steel) mounts, anyone ? im ready too order a set but I want the best fitting pair available. thanks again, Mike
Stay away from LMC parts they suck. I got my cab mounts from them and The fitment of them was bad and they are thin and will crack within acouple years. Check out this thread should help your decision be easier.
The LMC cab mounts are made of thin metal and hardly fit correctly whereas the DC ones use the original Ford sheet metal dies to form the metal and as you can see here in an LMC-DC comparison, are made much better.
Originally Posted by orich
Well when it comes to oem or oh crap from LMC this what you get in a few yrs see those crack lines in this thin stamped out sheet metal. Then look at the 2nd picture DC OEM one
you get what you pay for.
DC below any question?
