FE Intake manifold
Old Jun 6, 2014 | 11:15 PM
jmstenseth's Avatar
jmstenseth
FE Intake manifold
I was able to get a free 4 barrel intake manifold that's in great condition. The casting date indicates it to be a 1960? (COAE 9425 B) (OA19)
My question is this: Will it be a problem installing on my 1966 F100 FE352 that presently has a two barrel intake?
Thanks, JMS
Old Jun 7, 2014 | 06:43 AM
yetiman38237's Avatar
yetiman38237
Does the donor intake have the water neck? I think it is a different size than the 66??? Other than that should just be some minor plumbing/linkage adjustments...
Old Jun 7, 2014 | 10:22 AM
jmstenseth's Avatar
jmstenseth
FE manifold
Here's what the water tube looks like (bypass?)
JMS
Old Jun 7, 2014 | 10:26 AM
jmstenseth's Avatar
jmstenseth
FE manifold
Here's another view from a different angle. Thermostat hole measures 2 1/8" i.s dia. with a mic. It did not come with the water neck for the thermostat.
JMS
Old Jun 8, 2014 | 10:01 AM
MIKES 68 F100's Avatar
MIKES 68 F100
you will have to buy a thermostat and water neck for a 1960 car /truck otherwise should bolt on
Old Jun 8, 2014 | 10:50 AM
yetiman38237
If you aren't using the boss on water neck for the temperature gauge you can order one at Advance Auto for about $12. I ordered for a 1965 Galaxie 500 with a 390 and it works great......
Old Jun 15, 2014 | 01:11 PM
1972RedNeck's Avatar
1972RedNeck
If I remember right, my '66 took the bigger thermostat.
Old Jun 16, 2014 | 02:24 AM
jmstenseth's Avatar
jmstenseth
FE manifold
Thanks guys!
Old Jun 28, 2014 | 07:46 AM
jmstenseth's Avatar
jmstenseth
FE intake
Found another cast FE intake with a late 65' cast date. If anyone needs the 1960 intake I have please contact me.
bamaf150
Jul 14, 2011 03:45 PM
atomicjoe23
Aug 15, 2010 09:13 PM
HighdefJoe
Aug 16, 2008 06:18 PM
oldmansimek
Jan 18, 2006 11:11 AM
deisele75
Nov 16, 2005 07:45 AM
