Intake Manifold Identification
Old Jan 16, 2006 | 09:12 AM
oldmansimek's Avatar
oldmansimek
I posted a message before you guys told me to get the # on the manifold I have it. C4SE 9425A If anyone can tell me what engine this manifold was on and the vehicles if possible
Old Jan 16, 2006 | 04:31 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
That was used on both 352's and 390's in 64. Cast iron single 4bbl. Full size Ford and Merc. Probably T bird also. The T birds used a angled spacer under the carb. You need to measure the bore and stroke to find the real deal on your engine. A lot of stuff could have been changed over the last 42 years unless your postive the engine was untouched.
G.
Old Jan 16, 2006 | 09:48 PM
oldmansimek
Thanks the intake manifold I have is not from my motor my buddy gave it to me because he couldn't put a thermostat in it which is pretty weird. The hole for the thermostat is huge the housing barely covers it.
Old Jan 17, 2006 | 03:23 AM
Bear 45/70's Avatar
Bear 45/70
There are two different thermostats used. An early large diameter and the later small diameter. Different thermostat and goose neck (water outlet housing) required.
Old Jan 17, 2006 | 10:23 PM
oldmansimek
Do you know how big the larger thermostat is because I've been working on vehicles a long time and I've never seen anything this big on any vehicle I checked at the local parts store and they had no clue as usual will have to check some of my older 390 motors laying around.
Old Jan 17, 2006 | 11:37 PM
Bear 45/70's Avatar
Bear 45/70
The numbers on the manifold say it is a 1964 manifold. So go in and ask for a thermostat and water outlet/thermostat housing for a 1964 Galaxie with a 390. They should show a different number than the later trucks.
Old Jan 18, 2006 | 05:47 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
It's aprox 2.5" diameter. I have one in a NAPA box with a "191" number. This will also cross reff as a Mopar application besides Ford. Should be no problem finding one. Ask for one for a 74 318 Dodge. Same part as the large Ford one.
G.
Old Jan 18, 2006 | 10:41 AM
oldmansimek
Thanks guys will have to try that if that doesn't work I'll measure the hole and let you guys know
Old Jan 18, 2006 | 11:11 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
There is also an adapter you can buy to use a smaller stat in a larger stat intake. A guy named Bob Hasty sells them on ebay and www.fordfe.com. Something like $7 to your door. I have one and they work well. I can get you his contact info if needed.
Just thought of this.
G.
76Super
Nov 16, 2016 07:41 AM
BEN WHEELAN
Apr 6, 2015 06:33 AM
Falcon Guy
Apr 7, 2009 03:51 PM
YoungMT Hick
16
Mar 18, 2007 12:05 PM
HardFordCore
22
Aug 30, 2003 03:25 PM
