390 S code intake
Old Jul 8, 2011 | 10:08 AM
bamaf150's Avatar
bamaf150
390 S code intake
Would an S code iron 4v intake advertised off of a 66 maurader be a decent replacement for a factory 2v intake on a mild build 390 in a '76 F100 4x4? I know they weigh a ton but if the preformance is fine vs alum I dont see paying the $200-300 for an aftermarket alum intake. Could I still run EGR on the iron S code? Thanks
Old Jul 8, 2011 | 11:01 AM
bamaf150's Avatar
bamaf150
BTW, does anyone recoginise this intake? Says its for an FE but whats the water inlet doing on the back?
http://cgi.ebay.com/ebaymotors/ws/eB...m=280706784244
Old Jul 8, 2011 | 05:09 PM
85e150's Avatar
85e150
From what I can gather, that "water neck" on the back of that manifold should be a crankcase breather.
Note the item on this manifold:
C3AE-9425-K
Note the water inlet/thermo housing faces forward on the FE manifold, second pic down here, left of center as you look at the pic:
C4AE-9425-G
That was the crankcase ventilation method before the PCV was implemented. Note also those manifolds have the oil fill/breather at the front, again left of the water intake.
As for the S code manifold, posts I've read here indicate it is a good manifold, other than the hernia factor in picking it up.
Old Jul 14, 2011 | 01:00 PM
cooter455gs's Avatar
cooter455gs
I HAVE A C8OE-9452-C-9E17 AND I BELIVE IT IS ALSO A FACTORY HIGH RISE MANFOLD
Old Jul 14, 2011 | 03:44 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
It's a factory 428CJ manifold. 9E17 is the date code of 69-April-17th.
Old Jul 14, 2011 | 03:45 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Mustang 428 Cobra Jet Registry click on component ID section and you'll see the intake manifold and numbers. Or also on mustangtek too.
Mercmeister
38
Mar 27, 2022 11:45 PM
HANDSOME
Oct 19, 2015 12:47 AM
Kalve
13
Oct 11, 2010 09:52 AM
46yblock
25
Dec 15, 2009 01:15 AM
WillFordTruck
Aug 14, 2007 07:13 PM
