Need help with engine setup
Old May 21, 2014 | 07:22 PM
redroad's Avatar
redroad
@77&79F250 didn't see your post
Old May 21, 2014 | 07:24 PM
gatorfor88's Avatar
gatorfor88
Seems as though his main problem may be the nut that holds the wheel.
Old May 21, 2014 | 07:40 PM
Dillon31's Avatar
Dillon31
Originally Posted by redroad
Are you sure ? It sounds like the motor"s electrical system is completely disconnected from the Truck
See here also
I'm an electrician... Therefore electrical is no problem.
Old May 21, 2014 | 07:42 PM
Dillon31's Avatar
Dillon31
1. X2 Dillon on just relax and give us a few minuets, alot of us do not just set around waiting on opportunities to help, so yea maybe more than just 10 minuets ok?
2. DO NOT wise crack or get lippy with fmc400, you need to be way more open minded and polite, yes I said POLITE. You know the saying, more bees with honey than s$%^?
Got some $ to spend? http://www.summitracing.com/int/sear...=351M%20intake
Better get a carb to go with it, might as well get a 400 crank and make that 351M a 400 and then get serious about it.
Read and learn History of the Ford 351M
Keep reading...M-Block 351M/400 Parts Reference
And a touch more....351M/400 Performance Build Up
Take that attitude here lol, they will really welcome you....351M, what are some tricks to this motor - Pirate4x4.Com : 4x4 and Off-Road Forum
If you want to get serious. http://www.tmeyerinc.com/
Golden rule? He popped off at me first.
Old May 21, 2014 | 07:43 PM
Dillon31's Avatar
Dillon31
I know. He has some serious anger problems :3
Old May 21, 2014 | 07:48 PM
fmc400's Avatar
fmc400
MSEE
He's talkin' about you bud.
Old May 21, 2014 | 07:49 PM
Dillon31's Avatar
Dillon31
That's called sarcasm.
Old May 21, 2014 | 07:50 PM
Dillon31's Avatar
Dillon31
Also, I already replaced the steering wheel. So no problems there. How bout' some help now?
Old May 21, 2014 | 08:06 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Ah... Dillon that was not a "pop" by no means. He just said some things that you did not like and lets all just leave it at that.
Well I was thinking my links were help, were they not? You can get a bunch of opinions off here, or not.... it a real open ended question like "what color should I paint my truck". Well I like red and or blue, but there are a lot of other options and combinations you can go with.
I say a do an aluminium intake and 4 bbl and drive on. You can "straight up" time it and get some more. A new cam might warrant other new parts to go with it. Valve springs ect...
And like suggested in the 1st place the 335 engine series forum has a ton of threads to read thru also.
335 Series- 5.8/351M, 6.6/400, 351 Cleveland - Ford Truck Enthusiasts Forums
Old May 21, 2014 | 08:13 PM
Dillon31's Avatar
Dillon31
Yea, let's put it all behind us XD. Anyway, do you have any specific intakes to recommend? I have a 4 barrel edelbrock, but I was thinking going to Holley. I was also thinking mechanical instead of vacuum secondaries.
Old May 21, 2014 | 08:26 PM
77&79F250's Avatar
77&79F250
I run a Edelbrock intake and Holly carb with an Off Road kit (stiffer spring) in it on the ol red truck, and the 351M gets around ok for me.
"Straight up timing" is the cheaper way to go 1st, read the links about it.
And or here you go more ideas.
https://www.ford-trucks.com/forums/1...g-project.html
Old May 21, 2014 | 11:38 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I don't have any electrical problems. Lol
I know. I was just saying if you ever do have any electrical problems, fmc400 is the guy to go to. Even though you're an electrician, these trucks can drive anyone nuts sometimes when it comes to electrical issues. Never hurts to get expert opinions on problems.
maverick600
19
Feb 7, 2013 11:38 AM
Talyn
116
May 4, 2011 11:08 AM
chaser1602
1997 - 2003 F150
Nov 30, 2010 07:55 AM
1.3mazda
Feb 4, 2008 08:38 AM
cfrives3
1978 - 1996 Big Bronco
18
Nov 14, 2007 07:40 PM
