Sponsored by: Auxito
Your performance intake ideas
Old Nov 29, 2010 | 09:31 AM
chaser1602's Avatar
chaser1602
I need to replace the seals on thr intake water crossover. Since I need to remove the intake its a good time to upgrade the intake. I havent looked to hard for one. I thought i would get some ideas and thoughts from you guys first. What you have done, were to get it, what brand.....
Old Nov 29, 2010 | 09:38 AM
shotgunz's Avatar
shotgunz
http://www.f150online.com/forums/art...ight=gotts+mod
Old Nov 29, 2010 | 09:53 AM
chaser1602's Avatar
chaser1602
Been there done that,moved on.Got CAI and plumbed it to take air from below radiator
Old Nov 29, 2010 | 06:06 PM
galaxie641's Avatar
galaxie641
Which engine and year? There is next to nothing for the 5.4L if you are talking about replacing the actual intake and not just the intake tube. If you have the 4.6L there are some intakes and I don't know if there is anything for the 4.2L, I doubt it. If you have a NPI engine then a PI intake would be the trick but you'd need adapter plates.
Old Nov 29, 2010 | 06:11 PM
chaser1602's Avatar
chaser1602
I went to the local mustamg shop today. There is nothing for a 5.4. Oh well
Old Nov 29, 2010 | 06:24 PM
steve(ill)'s Avatar
steve(ill)
your manifold may be damaged where the water tube bolts to it. THe manifold has an o-ring groove cut in it and the lip breaks off and the o-ring slips into the water jacket and causes the leak. I filled the o-ring groove with epoxy and filed it flat and put a gasket and RTV on both sides.
Old Nov 29, 2010 | 06:25 PM
steve(ill)'s Avatar
steve(ill)
https://www.ford-trucks.com/forums/8...d-on-5-4l.html
Old Nov 29, 2010 | 06:44 PM
chaser1602's Avatar
chaser1602
Thanks Steve for the link.Mine is leaking under the thermostat housing were the 3 bolts are at
Old Nov 29, 2010 | 08:43 PM
93 mix 'n match's Avatar
93 mix 'n match
buy some sheet metal and some tubing and make your own.
Old Nov 30, 2010 | 07:45 AM
benningstspeed1.0's Avatar
benningstspeed1.0
Old Nov 30, 2010 | 07:55 AM
chaser1602's Avatar
chaser1602
Wow those intake adapters are as much as some 4.6 manifolds I've seen. Just gonna stay with what I have
66_in_ky
Jun 25, 2012 06:40 AM
mainman
2004 - 2008 F150
Dec 31, 2009 08:11 PM
baldboyford
Mar 14, 2009 02:25 PM
tmuti13
2004 - 2008 F150
13
Dec 18, 2008 08:27 PM
MuchToMyDelight
Aug 10, 2003 11:29 PM
