I recently had a thread going regarding my 1999 F350 2wd auto transmission slipping in/out gear. Tried to follow up on old thread but got confused so I'm trying to start a new one. Basic problem is that truck was slipping in/out of gear. Cleaned the solenoid pack electrical plug (as instructed on previous thread) and the truck didn't act up for 2 weeks. Today it started slipping in/out again and this time it registered a code of P0705. Curious if anyone has any input regarding what this is and what the solution is. Thank you.
Transmission range sensor, TRS circuit malfunction.
It sounds like the MLPS/ neutral safety switch has finally given up. Its what you cleaned out a few weeks ago. Also inspect the plug and make sure no pins got corroded off.
__________________
REPLACED SENSOR. had aamco install it they had done the transmission replacement twice this last year. code will still reapear. have to take overdrive off or around 65mph transmission acts up.any sugestions ? e250 2006 year
PCM (Powertrain Control Module) is the computer that controls the engine and transmission. While it is possible for it to fail, that is far less common than a wiring issue.
Hi, I am facing a problem with my truck, Ford F150 Harley Davidson 2011, code P0705. Backup camera off, lights off, from panel R, M, 2 and 1 not engaging. Reverse engages but takes some time, no reverse camera or back up lights. I found a broken part on the Lever, replaced the intire lever but the problem still. Please I need your help. I can't find the TRS sensor on the gear box on the driver's side... Where does it located? Any help please?
