Will do Tim. Biggest thing with brisket is it needs a low heat. I usually smoke around 175 to 200 degrees for 14 hours. Also it needs to stay moist so I use a mop sauce in concert with a good dry rub. For smoking I use either hickory or mesquite for brisket. Also a good fat cap is needed. Typically 1-2 inches thick. I smoke fat side up so as the fat melts it goes into the meat and flavors it and keeps it moist. Then let it rest for at least 15 minutes to lock in the moisture and the flavor.
This is some pics from the first brisket I did.
With the dry rub on.
The mop sauce
Just before one of the moppings to keep it moist.
Letting it rest
And one of the first slices after 14.5 hours of smoking.
