Virginia Chapter Join Chapter, Leader:
VA May (Spring) is here BS thread
Old May 23, 2014 | 07:39 PM
  #886
fire240's Avatar
fire240
Yes it is Tim. Cant be too careful with alot of those things anymore.
Old May 23, 2014 | 08:02 PM
  #887
archtaan's Avatar
archtaan
Nope, its just a shame that the news sensationalizes things so quickly.
All they had to say was "a suspicious device has been located and we are taking precautions to ensure the publics safety", but no. Its a bomb and they ran with that. Now they look dumb.
Old May 23, 2014 | 08:03 PM
  #888
fire240's Avatar
fire240
That is right on the nose Tim. The news has to sensationalize everything to scare people into watching what is going on. It's why I only watch it long enough for the weather.l Once I see the weather I change the channel.
Old May 23, 2014 | 08:07 PM
  #889
archtaan's Avatar
archtaan
Any plans for the weekend? I have a 3 day so I have no idea what I am going to do!
Old May 23, 2014 | 08:30 PM
  #890
fire240's Avatar
fire240
No real plans at the moment Tim.
Old May 23, 2014 | 08:34 PM
  #891
fire240's Avatar
fire240
Any plans for you Tim?
Old May 23, 2014 | 08:35 PM
  #892
archtaan's Avatar
archtaan
Gonna bbq for sure. Probably mess around the house and get caught up on stuff. Nothing exciting.
Old May 23, 2014 | 08:42 PM
  #893
Sparky83's Avatar
Sparky83
hmph... so much for good plans...
Old May 23, 2014 | 09:23 PM
  #894
archtaan's Avatar
archtaan
That gremlin kick your butt?
Old May 23, 2014 | 09:29 PM
  #895
Sparky83's Avatar
Sparky83
in a fashion tim.. the dangling piece was just a piece of electrical tape that came unwrapped... but while i was under there...
apparently oil is leaking.. and has saturated everything from the engine back...
Old May 23, 2014 | 09:46 PM
  #896
archtaan's Avatar
archtaan
Bedplate oil leak from the looks of the pics. Hard to tell though.
Old May 23, 2014 | 10:00 PM
  #897
Sparky83's Avatar
Sparky83
bedplate??
Old May 23, 2014 | 10:25 PM
  #898
archtaan's Avatar
archtaan
Yup, a know 6.0 leak source. Basically the plate between the block and oil pan that the rod caps bolt to it. They warp and leak. Throws oil on the sensors and causes issues. Sometimes appears to be a rear main seal leak. Its actually a pretty easy fix, just labor.
Old May 23, 2014 | 10:30 PM
  #899
Sparky83's Avatar
Sparky83
this seems to be coming from higher up though... that first picture is where the manifold bolts to the side of the engine.. which the valve cover sits right over it...
Old May 23, 2014 | 10:36 PM
  #900
archtaan's Avatar
archtaan
There is a plug up there to a sensor. ICP or something that leaks as well. Might be something as simple as a valve cover gasket. The pics make it hard to tell.
