Wiring harness problem
Old Apr 28, 2014 | 10:32 PM
johnwassink's Avatar
johnwassink
I knew I was having some electrical problems with some of the codes I was getting after a buzz test (High to low side open on cylinder #1,2,4,5,7) and cylinder #7 sounded especially weak and also got cylinder 1 glow plug circuit code. When ohm-ing stuff out I found that at the valve cover that everything checked out except for the glow plug on cylinder 1 (corresponding with the code I got)...#7 ohm-ed fine at the passenger valve cover. But what I found is that at the 42 pin connector the only injector that did not read was #7...
So if it has resistance at the valve covers but not the 42 pin connector, does that mean the wire is messed somewhere in btw there? I did not see any obvious problems and most of the wiring was in good shape.
Old Apr 28, 2014 | 10:40 PM
montanasteve's Avatar
montanasteve
It could be at the connector from harness to UVCH. Unplug it and check the terminals on both the UVCH side and the harness side - look for any signs of burned terminals on either plug. Other than that, one thing I noticed with my meter is that I have to "snap" the tip of the probe into the 42-pin female holes, but it sounds like you have that part figured out.
Old Apr 28, 2014 | 10:41 PM
montanasteve
What did you get for resistance on the #7 injector when read at the UVCH?
Old Apr 28, 2014 | 10:42 PM
johnwassink
It read around 3.5 along w/ the others
Old Apr 28, 2014 | 10:46 PM
montanasteve
That's good. Take a look at those connector pins. Meter the resistance from the #7 injector pin on the harness (where it plugs into the UVCH) to the #7 injector pin on the 42-pin connector. While you're doing that, move the harness around a bit at the UVCH side.
montanasteve
You should see around .2-.3 ohms.
Old Apr 29, 2014 | 07:08 AM
Tugly's Avatar
Tugly
0.2 - 0.3 is the glow plug, about 3.0 is the injector coil.
Old Apr 29, 2014 | 09:03 AM
montanasteve
He already metered the injectors from the UVCH. He wants to check the harness portion out, so metering from where the harness plugs into the UVCH (unplugged), back to the 42-pin, he should see .2 or .3 ohms.
Old May 12, 2014 | 08:46 AM
johnwassink
I must have made mistake while ohming out the connector at the valve covers cuz #7 injector didn't have power, so I pulled the cover and the wire going to injector was unhooked. Once I get everything back together I'll see how she runs.
Old May 12, 2014 | 03:01 PM
johnwassink
Running good!
Old May 12, 2014 | 06:05 PM
whitetmw's Avatar
whitetmw
Amazes me how some of these units are plagued with some issues and others not, and vice-versa.
Anytime I get a connector open, I'll use some aerosol contact cleaner and Dielectric Grease where they marry to keep moisture (and other stuff) out.
Glad you got it figured out.
If you ever replace your UVCH keep the connector with some wire length and it makes it a lot easier. Actually, I keep just about any connector from any vehicle where access is an issue.
Old May 12, 2014 | 07:21 PM
johnwassink
Thanks Tom! I have to get some of that contact cleaner. The connectors at the valve covers really need a good cleaning!
Old May 13, 2014 | 06:10 AM
Tugly's Avatar
Tugly
You may need new valve cover gaskets, if the contacts look bad. That would explain all the different codes.
I fell asleep on that ohming the conductor alone thing.
F350-6
Jun 24, 2012 08:32 PM
grantorino
Feb 21, 2009 01:52 PM
tony mathers
17
Nov 3, 2007 09:58 PM
gnarramo
Sep 12, 2006 11:01 AM
Brad4321
Sep 10, 2006 04:09 PM
