Broken Glow Plug/Injector Wiring Harness Plug
I decided to ohm all of the glow plugs and injectors pending the upcoming winter in my 1994.5 PSD. When I removed the front plug from the driver side right behind the AC compressor, it came off easily like the rest. However, both glow plug pins on the connector were broken off and still attached to the pins in the valve cover (I didn't do this taking the plug off). The plug smelled burnt. Since only one glow plug was in spec, my plans are to replace all of the glow plugs, wiring harness, and possibly to injector o-rings at the same time. However, I don't want to put it back together with this broken and probably unworking connector.
What can I do to fix this? Is going to a junk yard, cutting off a connector, and then putting the new connector on my wiring harness my only option? Considering the voltage that is running through this connector and the good connection that it probably needs running the injectors as well, is this even an option?
Here is some #'s that may be helpful...........
Valve Cover Harness Repair Kits (contains 4 hard shells w/seals, w/o terminals)
(Ford) F7TZ-14489-BA (94-96)
(Ford) F7TZ-14489-AA (97)
(International) 1830829C91 removal tool and Shells w/o pins
(International) 1661875C1 Pins
(International) 2501055C1 Pins with 6" wire
Valve cover harness replacement terminals:
Industry P/N 103935; Winzer Distributing (1-800-527-4126) selection number D52
Valve Cover Gasket (94-97)
(Ford) F4TZ-6584-A
(International) 1818350C2
Valve Cover Harness, under valve cover
(Ford) F4TZ-9D930-K (94-97)
(International) 1815923C92 (94-97)
(Ford) F4TZ-6584-A
(Ford) F4TZ-6584-A
(Ford) F4TZ-6584-A
rubber plug 1652325c1 how ever many 6" long wires with pins you get you also need tht many of these.
i edited his list some. the connector repair kit from ford is about $80.00.
here is an album of mine which may be useful. oh btw i dont recommend the pins with out wires either.
i also suggest powerstrokeshop.com for the uvc's and gaskets and the other parts from ih. cheapest way.
pics
Thanks for the part numbers everyone. It looks like I have plans for next weekend...
When you buy the plug, you just get the plug itself for $80? Do the factory wires come out of the plug and are reusable (since they are undamaged)? I ask because I am a little confused on what the 6" long wires are used for.
well for 30 dollars from ih you get all 4 plugs and everything in THIS PICTURE that sounds like all you need.
lhud
33
05-04-2023 12:50 PM
Fixnstuff
07-14-2017 06:41 PM
Bubba Jones
24
05-21-2016 08:11 PM
Gary (UT)
17
03-29-2013 05:05 PM
flainn
25
03-30-2011 11:07 AM
1994, 60, 96, controller, f250, f4tz9d930k, ford, glow, harness, international, plug, plugs, wire, wiring, wiringharness
