green antifreeze
Old Apr 12, 2014 | 04:20 PM
skytrash's Avatar
skytrash
green antifreeze
just bought a 2006 f350 and i noticed it had green antifreeze in it. is this a major no no or will it be ok?
Old Apr 12, 2014 | 04:27 PM
KDAVID1's Avatar
KDAVID1
Not good!!
You will want to get it out of there.
Old Apr 12, 2014 | 04:36 PM
skytrash's Avatar
skytrash
that bad huh
Old Apr 12, 2014 | 04:48 PM
69cj's Avatar
69cj
It needs to be thoroughly flushed and replaced with a 50/50 mix of Ford Premium Gold, Zerex G05 or a silicate free elc coolant.
Old Apr 12, 2014 | 04:52 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Unless it was Ford Gold with the add pack, which turns it a shade of green.
Either way, to be safe you'll need to flush and refill.
JOsh
Old Apr 12, 2014 | 04:55 PM
skytrash's Avatar
skytrash
ok thanks alot for the answers
Old Apr 13, 2014 | 12:14 AM
04badford's Avatar
04badford
JOsh
What is this add pack ? from ford or ?
Old Apr 13, 2014 | 07:25 AM
Bullitt390's Avatar
Bullitt390
Motorcraft VC-8
https://www.fcsdchemicalsandlubricants.com/main/product.asp?product=Diesel%20Cooling%20System%20Ad ditive&category=A/C%20and%20Engine%20Cooling%20Products
I like the "now dyed yellow to avoid confusion" part LOL
Josh
Old Apr 13, 2014 | 08:54 AM
Snowseeker's Avatar
Snowseeker
Mine had green when I got it with 180K miles on the clock. It just had a bad lifter.
Old Apr 13, 2014 | 07:34 PM
lwems's Avatar
lwems
If that antifreeze is conventional green, or Ford Gold tinted green, or any other silicate-containing antifreeze, then one of two things will happen:
1. You do an EGR delete and are fine forever; or
2. Your oil cooler will periodically clog with silicate gel, causing a cascade of secondary problems.
The EGR cooler runs too hot for silicate anti-freeze; this is one of the critical design flaws of the 6.0. Unfortunately, admitting this would instantly bankrupt Ford. In order to keep the tens of billions of repair costs firmly on the customer's shoulders, Ford cannot admit this problem, and so your Ford dealer must tell you to use the factory Ford Gold coolant.
Old Apr 14, 2014 | 10:18 AM
bismic's Avatar
bismic
I disagree - The Ford Gold works just fine in MANY MANY trucks. It is a low silicate formula and the silicate content is very small. With proper maintenance, snowseekers experience (see post above - 180k miles and no problems) is the norm assuming proper maintenance and operational practices. That being said, the diesel rated ELC coolants (non dexcool) do seem to be more robust (ie do not require flushing at 50k miles) and are a good choice.
Old Apr 14, 2014 | 10:59 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Green stuff killed my neighbor's '04 F250...
His degas bottle cracked, he bought a new one, and refilled with the green stuff thinking it was ok to use. A clogged oil cooler later, he regretfully sold his truck and now drives a Chevrolet.
Flush and refill with an ELC Shell, CAT, and I believe Chevron makes the ones commonly used. They're all Red in color and make sure to get the concentrate version and not the 50/50 premix.
A diesel site coolant filter would a good added layer of protection.
Old Apr 14, 2014 | 12:30 PM
lwems's Avatar
lwems
I'm sure a lot of people get away with having low or high levels of silicates in their cooling system. But that's not a roulette wheel I feel like spinning... I've already got stupidly large amounts of money and time invested in these engines.
The way I see it -- no amount of regular maintenance can prevent the EGR cooler from cooking the silicate coolant into gel, or prevent the gel from clogging the oil cooler, etc. It may hit you, it may not hit you, it's random chance, and that makes me crazy.
That said, I am glad to hear your 6.0 is well, and I hope it stays that way forever.
Old Apr 14, 2014 | 04:07 PM
Forddiesel06's Avatar
Forddiesel06
Get that green coolant out, flush it and only use ford gold coolant.
Old Apr 14, 2014 | 08:25 PM
Snowseeker's Avatar
Snowseeker
Do an egr delete and run whatever.
SC_Dave
19
Aug 24, 2015 04:18 PM
JAMSRF250
Sep 18, 2013 11:04 PM
jaybird8269
Jul 27, 2013 04:28 PM
Crewcab Turbo
Dec 18, 2011 04:31 PM
BigNiner19
2004 - 2008 F150
Sep 1, 2008 10:47 PM
