How do find the right key ignition timing?
Old Apr 5, 2014 | 04:23 PM
bub80z28's Avatar
bub80z28
I think the timing is off on the key ignition because the fuel pump doesnt turn on and the guage cluster is not right. how do you find the timing right?
Old Apr 5, 2014 | 09:02 PM
dixie460's Avatar
dixie460
I don't understand what timing you're talking about.
One thing at a time...
What are you working on? Year/model/engine/single or dual tank?
What ain't right with the gauge cluster?
Old Apr 6, 2014 | 08:17 AM
Eddiec1564's Avatar
Eddiec1564
Did you replace the ignition switch? It may not be aligned right and you will have to drop the column down to adjust it. Its a PITA to do but I have done it, just move the switch is VERY SMALL amounts and repeat till you get it correct.
Old Apr 6, 2014 | 08:20 AM
tjc transport's Avatar
tjc transport
i ain't rite
you just changed the actuator, correct?
you are going to have to take the column back apart and properly align the rack to the key cylinder.
the way i do it is to mesh the end gear of the key cylinder side to the end gear on the rack side.
Old Apr 6, 2014 | 08:32 AM
bub80z28's Avatar
bub80z28
Yes I did change the actuator been trying many combinations on gears but havent found the right one been a super PITA more than I expected.
Old Apr 7, 2014 | 08:54 AM
jas88's Avatar
jas88
Put the ignition switch (the one on top of the column) in the 'on' position, then set the actuator gear (the one that is made of brass with many teeth on top and only one on the bottom) down in the hole with the little tooth on the bottom lined up with the slot at the bottom of the hole. You have to get this lined up right or else your lock cylinder won't go back in.
quakerj
Nov 3, 2017 08:04 PM
Rollingscrapmetal
Oct 21, 2017 10:44 PM
rusty_tank
Aug 19, 2016 05:08 PM
qman
17
Jan 24, 2007 02:00 PM
JDPoore
Dec 26, 2004 07:14 PM
