Ignition Switch Positions
Old Aug 19, 2016 | 08:23 AM
rusty_tank's Avatar
rusty_tank
Hello All,
Quick question here what are the positions of the ignition switch?
I had an upper actuator rod failure on a 89 F150 Manual Transmission truck. I was able to get the new rod in and now the ignition switch operational, but I think it is missing a position.
Insert the key turn it forward to start the truck (it starts), Position 1. Release key starter disengages engine continues to run, Position 2. In order to shut the tuck off I have to hit the button on the bottom of the steering column and turn the ignition cylinder back to the lock position, Position 3. From there I can turn it backwards to the Accessory position.
Should I be able to cut the truck off without pushing the button on the steering column?
Old Aug 19, 2016 | 08:45 AM
subford's Avatar
subford
Yes you are missing the off position:
Old Aug 19, 2016 | 09:10 AM
rusty_tank's Avatar
rusty_tank
Thanks for the quick reply.
I guess the round gear the spade end of the ignition switch slides into has gotten off time from the flat gear that it pushes against pin on the upper actuator.
Does anyone have know of any timing marks to look for?
Old Aug 19, 2016 | 05:08 PM
tjc transport's Avatar
tjc transport
i ain't rite
i align the end gears before putting them back together. this usually get the timing rite.
sometimes i have to play with it though. some trucks just refuse to play nice.
conrad10781
13
Nov 27, 2024 04:24 AM
BuckHunter1960
May 22, 2016 03:47 PM
Silvestris
Apr 8, 2013 12:38 AM
jrv
May 16, 2008 08:49 PM
Kallie
1978 - 1996 Big Bronco
Jul 1, 2003 03:07 AM
