Ignition Switch Spins
Old Jan 16, 2007 | 05:21 PM
qman's Avatar
qman
92 F150. My ignition switch will spin all the way around without the key in it. It's not a problem to me until I let my wife drive the truck. I know how to insert and remove the key without messing up the alignment of the switch but when I get in after she drives it's all screwed up and it takes me 10 minutes to get the key in. Anyway, are these easy to fix, and how do I do it? BTW, it has a lever that has to be pushed in before the key will come out.
Old Jan 16, 2007 | 05:29 PM
quicklook2's Avatar
quicklook2
turn key to run and stick a 1/8" drill in hole under key, bottom of column, pull out and insert the new cylinder you bought.
or take old one to locksmith and have them rekey one for your door key.
Old Jan 17, 2007 | 12:12 PM
qman's Avatar
qman
That simple eh. Where do I buy one? Thanks.
Old Jan 17, 2007 | 12:35 PM
quicklook2's Avatar
quicklook2
advance, napa, pep boys really anywhere.
Old Jan 17, 2007 | 03:58 PM
qman's Avatar
qman
I was just online and it looks like Autozone has one for less than $20 and it's on my way home. My doors and ignition have the same key. I guess I'll have the new cylinder keyed to match the old.
BTW, what is it that wears out? Is getting a new cylinder gonna fix it? I ask because as I look at it it's that outer chrome ring thing that you see that spins. That thing looks like it's spinning around the cylinder. After my wife drives it I have to keep messing with it til I get things lined up correctly.
Old Jan 18, 2007 | 03:15 PM
doodaa's Avatar
doodaa
Originally Posted by qman
.... My doors and ignition have the same key. I guess I'll have the new cylinder keyed to match the old.
Actually half the key is for each function. The two tumblers in the center are shared but the tip is for the igniton and the "bottom" is for the door. Won't matter much if you're just getting the new cylinder matched to your existing key but make sure those two center ones don't get changed unless you want to do the door cylinders too. The door cylinders aren't near as easy to get at...
Old Jan 20, 2007 | 02:19 PM
qman's Avatar
qman
I just tried the 1/8" drill bit and it didn't work. The hole under there is just a big hole and the bit doesn't hit much of anything. I have a shop manual and what I'm dealing with it calls a key set and it looks like there is some sort of retaining screw inside the column under the steering wheel. What gives?
Old Jan 20, 2007 | 02:27 PM
Old_Paint's Avatar
Old_Paint
Can't help you with the spinning part. But, after I unlock the column, I don't need the key in mine, LOL. Freaked my daughter out one day when I was driving down the road, pulled the keys out and handed them to her and said "Here, hold these". It's been that way for years with no other adverse effects, so I don't worry about fixing it. The key comes out after I start the truck in ANY position, but is still required to unlock the column.
But, it does sound like something's come loose inside your column. Probably going to have to pull the covers off it to get a better look. Apparently there have been some issues with parts in the columns breaking.
Old Jan 20, 2007 | 02:47 PM
quicklook2's Avatar
quicklook2
get a light and get under and look in that hole.
it is a little pin you have to press.
i am positive this is how you do it in a 92 and up.
Old Jan 21, 2007 | 09:02 AM
Scndsin's Avatar
Scndsin
The key needs to be in the "run" position for the release button to work. My Chiltons has a long drawn out procedure for drilling/disassembly if key is lost, broken, etc.
Old Jan 21, 2007 | 10:41 AM
quicklook2's Avatar
quicklook2
already said needed to be in run position.
you just need to find the pin to press in.
Old Jan 21, 2007 | 11:34 AM
Scndsin's Avatar
Scndsin
Sorry, Seemed as it needed mentioning again. And also there are procedures for getting it out if you can't turn it to run.
Old Jan 21, 2007 | 12:01 PM
arctic y block's Avatar
arctic y block
See them use a dent puller on TV. The one ya got ta screw in. Ah don't try it if ya loose your key. A lock smith is way cheaper The bad part was he was laughing so hard it took him an extra 1/2 hour to fix it. Now before ya think what kind of dummy is this guy. It wasn't me, some chick tried to go joy riding and ended up breaking the screw off in the key hole.
Old Jan 23, 2007 | 04:46 PM
qman's Avatar
qman
I figured it out. I just wasn't hitting the pin quite correctly and I was reading the wrong shop manual. Funny thing is, it was my neighbor who noticed I had the wrong shop manual. He comes in and says, "I thought you were having trouble with your Ford" because he saw my Suburban shop manual sitting on the counter. The switch comes right out when you hit the hole correctly. I bought a new one from Autozone for $16. I had thought that the spinning chrome ring could be a problem but it turns out that nothing bad could have come of it. I could have left it like that forever and it would have never been a problem. Oh well, I'd prefer it work correctly.
Old Jan 23, 2007 | 04:52 PM
quicklook2's Avatar
quicklook2
now, wasm't that easy?
it does help to use the right manual, but you really did not need it for this repair.
