voltage to high?
Old Apr 6, 2014 | 11:25 AM
wiarde's Avatar
wiarde
voltage to high?
Have a 90 f150 5.8 and Was checking my tps and map sensors and the voltage supply from pcm was 6-7 and its only supposed to be 5 do i have a short or is it still ok didn't want to fry any of those sensors I think my tps went bad already
Old Apr 6, 2014 | 12:25 PM
subford's Avatar
subford
Yes that is too high. As you say it should be 5.0 Volts DC.
It does not sound good for the Computer but it may be you will just have to replace the Caps in it to get the 5 volt supply working OK.
Old Apr 6, 2014 | 12:45 PM
timbersteel's Avatar
timbersteel
I agree with Subford.
The capacitors may be/sound like they are failing. They act as a buffer and control voltage out, helping to clean voltage and keep it consistently.
What brought about your reasoning for checking the 5 volt reference on these sensors?
Old Apr 6, 2014 | 01:04 PM
wiarde's Avatar
wiarde
I got a code for low voltage on tps 63 I think and the voltage was higher then 5 so I decided to check another sensor map was easily accessible so that's why I have a new tps sensor. But not installed yet. Where are these capacitors at? I figured if it was a short it would be the higher then 7 volts. Any way to test these capacitors are they easy to replace?
Old Apr 6, 2014 | 02:02 PM
subford's Avatar
subford
Here is a video showing replacement.
Old Apr 6, 2014 | 05:52 PM
wiarde's Avatar
wiarde
Here's what I found theres 3 blue ones here's the pic of two of them some black and blue acid . So this little bit would mess everything up ? I just replace these with the same type type it had before any other special requirements they have to be?
Old Apr 6, 2014 | 06:06 PM
subford's Avatar
subford
No just the same value and voltage rating.
You also need to clean the board up a little with stripper and bridge any traces that are ate through.
Old Apr 6, 2014 | 06:13 PM
wiarde's Avatar
wiarde
Ok I already found one of them on amazon with same uf and voltage I don't see anywhere it ate threw but I'll clean the old acid off thanks for the help
Old Apr 7, 2014 | 09:58 AM
RIKIL's Avatar
RIKIL
The voltage you are testing is VREF (voltage reference I think) from the PCM and like everyone else said, it shouldn't be higher than 5. If it is, something in the PCM isn't right. That's just a little background, sounds like you are on the right track to fixing it.
cricketo99
18
Jan 31, 2024 04:15 AM
pmibach
1978 - 1996 Big Bronco
Nov 10, 2006 10:12 AM
crazylegs
Electrical Systems/Wiring
May 27, 2003 05:25 AM
steve4413
Apr 8, 2002 01:37 AM
67Coupe
Feb 6, 2000 11:22 AM
