Oil leak
Old Mar 21, 2014 | 11:36 AM
engine14's Avatar
engine14
Oil leak
I Have a 1976 F-250 4x4 with a 360 engine. Bought the truck new and she still runs, problem is, back in 1981 one of the connecting rods took a side trip and took a couple of pistons with it. I bought a rebuilt and put it in. It ran fine but had a horrible oil leak since. Over the years I brought it in to different shops to no good end. Back in 2002 I had a friend rebuild the engine again, thinking we will get to this leak problem. Nope. I recently found the source of the oil leak with the help of my bride. because the oil pan sump is in the rear of engine, the dip stick goes through the oil pan. The problem is, where the oil filter bolts to the block, there is another hole just aft of it where the original dip stick went on the 2wd trucks. Now my question is, how do I seal this hole up???? or is it just as easy as it looks and shove something in it? Seems to me there would have been a proper way of doing this. Thanks for any help with this.
Howard
Old Mar 21, 2014 | 12:00 PM
Filthy Beast's Avatar
Filthy Beast
You can use those "mini" freeze plugs. I ferget the real name but a machinist/builder should have a bunch of 'em. Pop them in just like regular freeze plugs.
Someone else here have the real name?
Edit: found my old pack.....from Ford dealer, service parts......EAA-6572-A....plug. Don't know if they're still available from Ford.
Old Mar 21, 2014 | 12:59 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Those are the plugs for the end of the rocker arm shafts. Not sure if they're too big for the dipstick tube or not.
If I remember right, the dipstick tube is 3/8" diameter.
But you are correct, they use a small core plug to plug the hole. I think they're the same size as the ones that come in the core plug kits, the ones that have the freeze plugs, cam plug and galley plugs.
As an alternative, you could tap, thread and install a pipe plug.
EDIT: I just did a search. If EAA-6573-A will work, there are over 300 at various Ford dealers and obsolete parts suppliers, but you should be able to get the plugs at the parts store....your best bet would probably be NAPA.
Old Mar 21, 2014 | 01:25 PM
engine14's Avatar
engine14
Thank you Guys.
As a quick fix I used some thick felt I had and shoved it in the hole. so far no leak. I will check for the plugs.
Howard
Old Mar 21, 2014 | 01:26 PM
Filthy Beast
Shoot, I must have gotten pooned on my old "plug and dowel kit" from Ford racing, Part # M-6026-R351.
No little plugs that I can see, and I'm not tearing open the package to check. I have enough of those "little" plugs for my needs anyway.
Thanks for the info, Mike.
Old Mar 21, 2014 | 01:28 PM
Filthy Beast
Originally Posted by engine14
Thank you Guys.
Howard
I hope you think about changing your oil and filter. Never know what goober stuff could have gotten in through that hole.
Good luck
Old Mar 21, 2014 | 01:32 PM
engine14's Avatar
engine14
Yes I am. Thanks
Old Mar 21, 2014 | 04:10 PM
Jklnhyd's Avatar
Jklnhyd
Why not run a tap into it, and seal it with a 1/4" long bolt?
Old Mar 21, 2014 | 06:06 PM
Blue and White's Avatar
Blue and White
If a 3/8" tap will make threads that's a great idea. If it won't, still a good idea. Clean the hole thoroughly with solvent like lacquer thinner, coat the bolt with RTV and push it in. Its not elegant but very effective and will hold up.
Old Mar 22, 2014 | 02:11 AM
MeanGreen460's Avatar
MeanGreen460
I have used a short bolt and silicone and tapped it in with a hammer may have to grind threads off bolt .Trying to tap the hole with a tap not the best idea because you will be getting metal shavings in your motor
Old Mar 22, 2014 | 01:36 PM
engine14's Avatar
engine14
The only problem I see is the hole is not perpendicular to block, but on a angle making it harder to tap. I'll see how the felt works for now but will probably take oil pan off and run bolt clear through with sealant.
Old Mar 22, 2014 | 04:13 PM
Filthy Beast
engine14;
If you have trouble finding a plug (if you're going that route), send me your address and I'll send you one.
birdboy
Aug 29, 2016 06:01 PM
Fat Fendered Ford
May 1, 2009 05:52 PM
Shep VA
Modular V8 (4.6L, 5.4L)
Mar 14, 2008 07:03 AM
lostmybeer
Oct 21, 2007 12:16 AM
Suber
13
Jun 11, 2007 12:26 AM
