Injector question.
Old Mar 19, 2014 | 06:04 AM
  #31
MisterCMK's Avatar
MisterCMK
Originally Posted by Bullitt390
2.5 hours seems typical. Throw in a few more minutes if you also change out the oil rail nipple o-rings.
Props to ya if you decide to change out the upper injector o-ring, that sucker is a bugger to change out.
Josh
The oil rail nipple requires the special tool, right?
Sent from my Telegraph using IB AutoGroup
Old Mar 19, 2014 | 06:20 AM
  #32
MisterCMK's Avatar
MisterCMK
Originally Posted by Yahiko
Do 3/7 share?
Sean
EDIT : I must be half asleep. I was reading firing order not locations.
Did you try running the relative compression test twice and see if the results are the same?
Old Mar 19, 2014 | 06:31 AM
  #33
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Yep, the special socket from Robbinhood or Cre8tor
Josh
Old Mar 19, 2014 | 06:32 AM
  #34
78fordman's Avatar
78fordman
Yes. I believe a site member sells them here. Robinthehood I think is his user name.
Sent from my leash using IB AutoGroup
Old Mar 19, 2014 | 06:35 AM
  #35
npccpartsman's Avatar
npccpartsman
Originally Posted by 78fordman
Yes. I believe a site member sells them here. ROBBINthaHOOD I think is his user name.
A little help on his name--LOL
Old Mar 19, 2014 | 10:52 AM
  #36
Yahiko's Avatar
Yahiko
Yes, Very close each time
Sean
Old Mar 21, 2014 | 12:23 AM
  #37
Yahiko's Avatar
Yahiko
Ratts just thought of something. I was running the SRL from Matt
when I did that power balance test.
Not sure if it will make any changes but I'll set it back to stock and re-run it.
Then I post the new ones to see if there is a change.
Sean
thelunkster
Oct 8, 2016 07:55 AM
ATV PRO #11
Jul 10, 2015 10:57 PM
Fallguy2004
Feb 22, 2012 06:53 AM
vlietracer64
Jan 26, 2011 05:13 PM
bill1187
Oct 19, 2009 11:48 AM
