Injector question.
Old Mar 18, 2014 | 07:19 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Look forward to it.
That China VCM is so tempting...
Josh
Old Mar 18, 2014 | 07:32 PM
Yahiko's Avatar
Yahiko
Originally Posted by Bullitt390
Look forward to it.
Josh
Glad someone is. I really don't want to do the work.
Sean
Old Mar 18, 2014 | 08:03 PM
Bullitt390's Avatar
Bullitt390
Sean
It's a lot easier than pulling intakes...
Josh
Old Mar 18, 2014 | 08:19 PM
MisterCMK's Avatar
MisterCMK
Josh
Pulling injectors?
Sent from my Telegraph using IB AutoGroup
Old Mar 18, 2014 | 08:50 PM
Bullitt390's Avatar
Bullitt390
Originally Posted by MisterCMK
Pulling injectors?
Yep...
Josh
Old Mar 18, 2014 | 09:27 PM
MisterCMK's Avatar
MisterCMK
Yep...
Josh
Hmm.
Pulling the intake isn't that bad. Maybe I should finally do something about my injectors...
Old Mar 18, 2014 | 09:35 PM
Yahiko's Avatar
Yahiko
Josh
Pulling injectors?
Yep...
Josh
You just had to bring the intake up. That is in the plan also. I need
to install my BPD EGR cooler. I talked to the people over at Fugate
Ford. They did head gaskets before I bought it and anytime the heads
are off they clean the turbo. So I won't have to do that unless I want
to with the way I drive. While the intake is off it's going to get a good
cleaning to remove all the carbon/soot. I do have an intact EGR system
but it's turned off with a tune.
Right now I guess I should go out and do that relative compression test.
Truck is nice and warm for the Costco run and dinner break. Yes dinner
at Costco Chicken Bake. Yummy!
Sean :drink
Old Mar 18, 2014 | 09:41 PM
Bullitt390's Avatar
Bullitt390
Hmm.
3 things suck about injectors:
1) Passenger side the lower 2 VC bolts if you don't have a 12mm flex ratchet wrench
2) Passenger side oil rail is a biotch without a stubby torx bit or at least a mini 1/4" ratchet
3) I hate removing the FICM brackets for whatever reason.
As for intakes, that part isn't bad, I despise re-installing the turbo no matter how many times I have done it.
Josh
Old Mar 18, 2014 | 09:59 PM
MisterCMK's Avatar
MisterCMK
Josh
Good info. I may have to polish my spool valves in a couple of weeks here. How long do you think it takes?
Old Mar 18, 2014 | 10:11 PM
Yahiko's Avatar
Yahiko
Ok I went out and did my last little test.
Here is the screen.
Sean
Old Mar 18, 2014 | 10:13 PM
Bullitt390's Avatar
Bullitt390
2.5 hours seems typical. Throw in a few more minutes if you also change out the oil rail nipple o-rings.
Props to ya if you decide to change out the upper injector o-ring, that sucker is a bugger to change out.
Josh
Old Mar 18, 2014 | 10:23 PM
Magnus E's Avatar
Magnus E
Josh
Agree on all three, so friggin tight in the engine compartment. My first truck (a Chevy C10) had so much space I could actually sit on the radiator, feet dangling inside the compartment and change plugs. On the Ex, I was hard up to find a spot to mount the relay for my lights. Things have changed.
On the turbo, the biggest pain IMHO is to align the exhaust on the turbo. Found that loosening the pipes at the exhaust manifolds made it real easy.
Old Mar 18, 2014 | 10:38 PM
  #28
Yahiko's Avatar
Yahiko
You know if you look at the two images
#7 is low in both.
Now how they relate I have no idea.
Sean
Old Mar 18, 2014 | 10:41 PM
  #29
Bullitt390's Avatar
Bullitt390
Worn rocker?
Josh
Old Mar 18, 2014 | 10:43 PM
  #30
Yahiko's Avatar
Yahiko
Do 3/7 share?
Sean
EDIT : I must be half asleep. I was reading firing order not locations.
