Bronco II Ford Bronco II
Warped front rotors
Old Jul 9, 2003 | 07:57 PM
rmyers2051's Avatar
rmyers2051
Warped front rotors
Originally posted by Hell_Fish
Let me re-word that. They can crack. The holes are the weak point. A slotted rotor is stronger than a cross drilled one.
Now why would you think that? If you remove metal by cutting a .187 hole you have effectively lost X amount of cross section.
If you cut a slot .187 wide in a rotor, to qualify as a slot it has to be longer than it is wider so you would lose even more cross section with one that has 10 slots spaced at 36 degrees than you would by drilling 15 holes in it. Slots are weaker because you remove more metal, holes that are properly chamfered will not be prime source of crack. Proven point many times over.
I do prefer slotted holes in mine. My last Mustang received them, did SCCA slalom racing with it. I do rotors for a performance company here in Lexington even though he can buy them off the shelf cheaper. Guess he likes my patterns!
Trannyman95
Mar 19, 2015 11:05 AM
bulletpruf
Sep 2, 2012 03:31 PM
buckeyebronco
1978 - 1996 Big Bronco
Mar 7, 2006 04:32 PM
cgl
Feb 3, 2004 02:12 PM
meclift
Sep 26, 2002 09:07 AM
