High idle opinion
Old Sep 8, 2010 | 07:48 PM
Acftmaintainer's Avatar
Acftmaintainer
High idle opinion
Yea just another question from the "new guy". I was wondering what people thought about the high idle mod. I am leaving for the big sand box in the east and i am leaving my truck with my fiancee. It gets about -20 or -30 in the winter here at times and i was wondering if it would be a good mod to do for her this winter and every winter to follow.
Old Sep 8, 2010 | 09:37 PM
riggz's Avatar
riggz
Is she going to be driving it around and letting it idle? If so then yes.
Is she going to start it up every so often and let it idle to move some fluids around? If so then yes.
Just make sure it's not done immediately upon start up. Let the computer idle up the motor on it's own then kick in the high idle.
Just FYI, these engines have a built in high idle. When the motors are cold and idling they will idle up quite a bit.
Old Sep 8, 2010 | 11:31 PM
joe blow's Avatar
joe blow
What he said.....although the truck does have a high idle, it will never reach the 1250RPM mark that the "manual" high idle mod will give you. It is not very difficult to do and if your truck came with upfitter switches already installed (4 switches built into your ashtray area) then it is that much nicer looking. If not then it is very simple to add a switch.
Old Sep 9, 2010 | 12:49 AM
flamebuster's Avatar
flamebuster
X-2.........................
Old Sep 9, 2010 | 09:02 AM
nitrogen's Avatar
nitrogen
no real biggie, turn switch on start truck and walk away, or like me. switch on when you park and use command start. if you actually try it you will notice it prob takes at least 5 seconds after it runs before it spools up. yes it is revving up fairly quickly pretty soon after startup but in a no load situation thats ok
Old Sep 9, 2010 | 10:35 AM
joe blow's Avatar
joe blow
Not to start a debate but.........................I disagree with what nitrogen said in regards to letting it go right to a high idle immediately upon startup....if that is what indeed what he meant....IMO you should atleast let it gain oil pressure at the low idle and run for a minumum of 30 seconds to 1 minute so things in the engine get lubricated and begin to warmup....just my opinion.
Old Sep 9, 2010 | 06:33 PM
nitrogen's Avatar
nitrogen
you have to remember our engines have to have significant oil pressure before they even attempt to fire. on my 05 doing exactly what Joe thinks i suggested, there is a noticable delay between the engine firing and actually revving up. keep in mind I run 5w40 synthetic which has good cold flow characteristics, and that i operate 600 horse cats which low idle at 1400 rpm and cat doesn't feel thats a problem even on cold starts. they do say to let it warm up before you start putting a load on it. ford itself suggests that 1 minute or less is adequaete warm up time if you drive moderately. if thats all you need before driving my thinking is that less would be ok just for high idling
Old Sep 9, 2010 | 06:39 PM
cheezit's Avatar
cheezit
the truck wont start with out lowside oil pressure.
