Rebuild question (heads)
Old Feb 18, 2014 | 05:53 PM
the5schlueters's Avatar
the5schlueters
I am looking to rebuild my 351w in my 92 f350 4x4 it is leaking out the rear main and it has quite a few miles on it so I figured its time for a rebuild. 1 of the heads needs to be replaced (long story with broke bolts from previous owner). I am curious what heads should I run? Stock heads or maybe aluminum heads??? Im not looking to build a racing engine or anything fancy but would like to get better fuel millage and maybe a little more power. I don't do much heavy pulling with it, I don't go mudding in it (I do pull people out of the mud and snow). Its not a daily driver ether but when I need to use it I NEED TO USE IT you know lol. I dont want to spend a butt load of $ on it ether. I just lost my @## on a mustang build that got smashed during the ice storm and that turned me away from working on cars and trucks. But I love my truck and its making me wanna start working on stuff again.
Old Feb 18, 2014 | 06:00 PM
Conanski's Avatar
Conanski
Look for a pair of GT40s... that is what should have come stock on all 5.8s in my opinion.
Old Feb 18, 2014 | 06:19 PM
Wolfjohn's Avatar
Wolfjohn
I agree on the GT40's (or the GT40P's for a slight more edge).
Old Feb 18, 2014 | 07:22 PM
the5schlueters
How much should I expect to pay for a set?
Old Feb 18, 2014 | 07:50 PM
Wolfjohn's Avatar
Wolfjohn
I've seen them from $350 to $600 for bare heads. Quite a few sites sell them including Ebay. Good luck on your truck!
Old Feb 19, 2014 | 12:12 AM
UNTAMND's Avatar
UNTAMND
Any junkyard with a v8 explorer will get you a set of heads cheap.
Then go from there.
If you're paying 600$ a set for bare heads, you may as well buy complete alum ones for a little more.
Old Feb 19, 2014 | 02:11 PM
the5schlueters
So what else did the GT40 heads come on other then the v8 explores? and what years so I can do some junk yard hoppin lol?
Old Feb 19, 2014 | 02:52 PM
Conanski's Avatar
Conanski
GT40 heads were found on '96 to '97.5 Explorers, '93-'95 Mustang Cobra, and all Gen1 Lightnings. The '97.5+ Explorer got the GTP head which actually performs a little better but has a radical spark plug angle(almost straight out) that makes fitting headers more interesting.... not impossible but not a simple bolt-on either.. some clearancing necessary.
Old Feb 19, 2014 | 03:34 PM
the5schlueters
I have shorty headers on it now.
Old Feb 19, 2014 | 06:43 PM
rla2005's Avatar
rla2005
Your best bet is sourcing GT40s or conventional plug location aftermarket heads like AFR, Edelbrock, etc. Those GT40Ps can be a bear to find headers for.
Personally I think the GT40s are over-rated and tend to draw too much money. I would use AFR, TFS, Canfield or other quality aftermarket heads before ponying up the bucks for a set of GT40s that may require rework to bring them up to snuff.
I understand you have a budget to work with but do not be swayed by the "GT40" moniker. They are a much better design than the awful E7 factory head but there have been 20 plus years of improvement in head design since the GT40s hit the market.
Old Feb 19, 2014 | 07:48 PM
MonroeHandyMan's Avatar
MonroeHandyMan
^+1 Absolutely!
Old Feb 19, 2014 | 08:01 PM
Conanski's Avatar
Conanski
+100.. I wouldn't pay more than $300 for a set that are ready to use, for $600 you could probably get some used aluminum heads off the local classifieds.
Old Feb 20, 2014 | 12:09 AM
42x's Avatar
42x
Actually the stock E7 heads are not bad if you grind down the smog bumps. Remember you will have to match you intake with the heads. The Al heads will give you about 10% better HP due to cooling. The GT40 heads have round intake so you will definitely need to match the intake. If you go the GT40 you need to look for the heads with 3 casting stripes, the GT40P's have 4.
Take a close look at total cost for rebuilding a set of heads -springs, valve guides, keepers, machine work vs the cost of a complete set of after market heads. Price is not too far off on a new set. Food for thought.
Apocalypse
Apr 22, 2018 04:22 PM
Redneck1465
Jan 19, 2009 01:03 PM
Snowking
Sep 3, 2007 06:23 AM
dieingford
Jun 26, 2004 04:46 AM
jaymaria
Sep 30, 2002 04:47 PM
