New truck and only 1 question so far
Hi I just got a 96 f250 4x4 7.3 and auto tranny 4in lift, so far ive replaced upper and lower ball joints both sides, all the front wheel bearings and replaced tie rods and all 4 shocks. The front end of the truck on the right side wants to sit sagged down, any ideas? the only thing left I can think of is leaf springs.
Hi Tyler,
Not sure if your issue is with the leaf springs but, if so, I Highly recommend ATS (Jr. or Bob) for replacements....they are extremely knowledgeable on all the issues on these Fords and their pricing is very good. I've been very happy with their products. Good luck!
Leaf Springs and Suspension Parts by Auto and Truck Springs
Thanks for the replies, if I back in to a parking spot I get negative camber on that tire if I pull into a spot the truck still leans tire straight but the lean of the truck isn't AS bad but its still bad, ive already done wheel bearings ball joints and tie rods as I stated earlier, any way to really check the leaf bushings or leafs?
I had that issue, come to find out the center bushing and bolt where the TTB "Hinges" together was worn out and had to be replaced. Seriously, when I would back up, the tires took on a pyramid shape. As soon as I had the front end shop replace it...the issue was gone. You might have a look at that. On the leaf numbers, I'd still talk to Bob or Jr. at ATS....they can do a cross reference on those leaf springs for you. I think JR. is on this board too.
Wonder how you check that cuz it wouldnt surprise me if thats the case, do you remember how much parts were? Ill end up doing it myself if thats the problem i cant afford to pay a shop, oh its only my passanger tire that will lean in when i back in, ill take some pictures and try to put them up
Dionte Reeds
01-10-2019 10:49 AM
3531351w
06-24-2007 12:35 AM
