351W Heads
Old Jan 14, 2009 | 11:02 AM
Redneck1465's Avatar
Redneck1465
351W Heads
I have an 85 351W that I am going to rebuild this summer. What is the best head for this motor without killing my pocket book? I am a college student with little money to spend but I want the most horsepower for my money. Also I dont want to be worrying about huge compression issues since I am not building a race car. Thanks again guys.
Old Jan 15, 2009 | 03:39 PM
Facemelter's Avatar
Facemelter
What kind of pistons,did you do a rebuild? You can probly get away with a very nice set of world cast Iron heads or some thing similar.Those dont cost much.
Old Jan 15, 2009 | 06:08 PM
Redneck1465
I havent rebuilt it yet there for the pistons and such are still up in the air.
Old Jan 16, 2009 | 12:41 PM
Facemelter's Avatar
Facemelter
What kind of rebuild would determine the type of heads you use.The stock heads are not that bad with some good port work.Or if you come across some,the old 351 4v windsor heads flowed really well.And they bolt right on.If you want to spend some cash then go with some thing cast iron.You can get mostly the same flow rates that you would from a set of good aluminum ones.
Old Jan 16, 2009 | 01:02 PM
Conanski's Avatar
Conanski
Best junkyard heads you'll find are the '96-97 GT40's from an Explorer/Mountaineer, just have to bore out the bolt holes to 1/2" and bolt these on. You can get similar performance from the E7's if you know how to do a complete porting job and install larger valves, but most people don't have the knowledge or necessary equipment so it's easier and more cose effective to just find a set of GT40's. For a little more money you may find some used World Jr's or Edelbrock heads, or you could invest in some prefessionally ported E7's like these Thumpers... Thumper of Orange Park
Old Jan 16, 2009 | 01:33 PM
Redneck1465
What about the GT-40P heads?? I have heard they can raise compression to much though.
Old Jan 16, 2009 | 03:43 PM
Facemelter's Avatar
Facemelter
You would have to have a machine shop drill the bolt holes to 1/2" for gt40 heads.The gt40p's also take a different exhaust header than typical E7,windsor heads.You also have to consider what cam and intake your running.You would want your combo to work together.You dont want HUGE flowing heads with a small cam.Or vice versa.I would consider what rebuilt you want and what kind of performance you want out of your rig.Then go from there.
Old Jan 16, 2009 | 10:01 PM
Franklin2's Avatar
Franklin2
I believe you are better off rebuilding the engine stock, and if you do not have emissions checks, run a little 600 cfm 4 bbl, and put a nice exhaust on it. You might want to put a mild rv cam in it, just make sure it will bolt in with the stock non adjustable valve train. With this setup it would have good power, good manners as far as idle quality, and you could still run it on cheap 87 gas.
Old Jan 19, 2009 | 01:03 PM
Redneck1465
I already have a 650 cfm 4BBl holley and a dual exhuast with flowmaster muffler setup on it. And emissions are not a problem for me as 10000lb plates do not require emissions
Aaron-71
Jul 7, 2010 01:07 PM
driverreturnonfoot
1978 - 1996 Big Bronco
Jan 14, 2010 07:47 AM
sweetsride
26
Nov 4, 2009 10:49 PM
choochoof150
Mar 14, 2007 08:58 AM
bshackelford711
Sep 14, 2006 12:16 AM
