DFCM draining...
Old Feb 18, 2014 | 11:09 AM
  #31
marchare011's Avatar
marchare011
Originally Posted by Bobbykjl
For something that has to be checked monthly...What a Pain in the A$$
It's really pathetic to watch my 78 year old neighbor cursing while climbing out from under his 2014 truck (from which he was laying on card board over the snow), with diesel all over his hands.
He has the same issue I have on my 2012. There you are, holding your mason jar under the DFCM drain port as you slowly turn out your yellow ****, patiently waiting for diesel to enter your jar at which point you turn your yellow **** back in and never spill a drop...right? Wrong! the diesel flows from the yellow handle all over your hand before it flow from the spout it was designed for.
I have read that others don't have this problem because they don't turn the handle that far out. He nor I will not get any flow from the drain port until we open the valve to the point it leaks from the ****.
I wonder if there is an o-ring missing on the other end of that yellow ****?
Old Feb 18, 2014 | 11:42 AM
  #32
Bobbykjl's Avatar
Bobbykjl
marchare011 - thanks for the intelligent response.
It could be something missing. When the truck hits its first service, I'll disassemble the unit and take a closer look. Sometimes things are missed during assembly and its not uncommon to be missed repeatedly if the assembly instructions are not corrected.
Old Feb 18, 2014 | 01:43 PM
  #33
PlayersZ28's Avatar
PlayersZ28
Mine runs down my hand as well when I do it. Maybe I'm opening it too far but if I don't go that far I get no flow.
Old Feb 18, 2014 | 02:11 PM
  #34
marchare011
I would also make sure the little hole in the drain isn't plugged. Maybe some debris or a casting flaw in the DFCM drain? I don't recall exactly how much I turn mine, but it isn't very much. Maybe a couple full revolutions.
Old Feb 18, 2014 | 03:02 PM
  #35
Bobbykjl's Avatar
Bobbykjl
Originally Posted by Hdslider
Bitch Bitch Bitch. A simple task. Sell it if it bothers yall so much. And buy a prius.
Sorry, you're right. It's a simple task and the drain port works perfectly. I shared your response with my neighbor and he finds it as funny as you do.
Originally Posted by rtazz17
Lol!!
Couldnt agree more!
I dont worry about this daily but when I go into a fuel station im on my toes..Double and triple check I hit diesel button,right hole ect.Look at it for a few more seconds then pump.Kinda crazy! Thats my ocd kicking in.Never had this type of experience fueling before my 6.7.
I guess I'll see you at the Prius dealer!
Old Feb 18, 2014 | 03:36 PM
  #36
jd350b's Avatar
jd350b
I asked my uncle to show me howto drain mine in case he's not around to do it for me. It went all over his hand too . I watched him turn it but nothing came out until it came out the yellow handle thingy.
I was going to ask about it on this forum but I already feel akward being a girl with such a big truck. I really don't want to "bitch" and be told to go buy a Prius. .
So I'll consider it normal and move on...
My friend that tows horses with her 2002 Lariat recommended I join this forum. She said hers is somewhere by the engine but she never drained it. I told her she should so nothing bad happens.
Old Feb 18, 2014 | 03:52 PM
  #37
senix's Avatar
senix
Anything prior to model year 2008 will tolerate water better. the fuel pump is not designed to lubricate by the fuel.
Only dumb question is the one not asked..gender neutral of course
Old Feb 18, 2014 | 04:38 PM
  #38
jd350b's Avatar
jd350b
Thanks so much Scott! I feel like such a tom boy, I like reading the forum posts. I've learned a lot from your posts! thanks!
Old Feb 18, 2014 | 04:40 PM
  #39
Hdslider's Avatar
Hdslider
You wont see me at a Prius Dealer. Im not the one pissing and moaning about a normal simple task. end of discussion.
Old Feb 18, 2014 | 06:20 PM
  #40
Bobbykjl's Avatar
Bobbykjl
"Normal simple task" (climbing under your truck with a jar)... Relative to the person climbing under their truck
"Pissing and moaning" ... Relative to the person reading the post
Misinterpreting who the "see you at the Prius dealer" was intended for...Relative to the person reading the post
You definitely could use some humility. Thousands of posts...many of them very helpful, many of them not. I read some of yours that portray some "pissing and moaning"
"end of discussion" what are you 12 years old?
For those interested, I spoke with my dealer and he said it's a common problem and they have had success by changing the O-rings. They will change them out when they do my first service.
Old Feb 18, 2014 | 06:51 PM
  #41
kper05's Avatar
kper05
Post up if the o-ring is the fix. Is it the o-ring on the yellow ****?
If it's as simple as that, it'll be a nice fix.
Mine has always been able to drain without dripping as long as the truck is level.
Even the slightest incline will mess it up.
Although...the manual does say to turn it until the o-ring is visible but that's what makes it leak.
It seems to drain fine stopping just before that.
I know I'm questioning the engineers from my arm chair but if you can do this cleanly, I think forcing it to leak is silly.
Old Feb 18, 2014 | 08:11 PM
  #42
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
For the guys that check for water more frequently than monthly...I'm assuming the reason is obvious (easy check to avoid a disaster) however isn't the WIF sensor located in the DFCM? If the sensor is working properly wouldn't it "sense" any small amount of water? Or does it take more to trip it? Of course if the sensor fails you'd find out the hard way. A redundant sensor would make sense.
I guess I'm wondering if the sensor is designed to tell you to drain the DFCM or is it to tell you "your in trouble". I never want to see my WIF light come on because then the PCM will always remember it. Imagine 30K miles later you have a HP pump fail and the dealer plugs in the diagnostics and says "ah ha!" you had a WIF sensor come on two years ago which means you in fact had water in the fuel which means you're warranty is denied
The WIF light = You've just lost $12,000 LOL
Originally Posted by Rod Bensken
I use a mason jar, put about 1 1/2" in it. Check it in a day or two. No water as of yet.
X2
Old Feb 18, 2014 | 08:41 PM
  #43
Chris Stewart's Avatar
Chris Stewart
Originally Posted by kper05
The DFCM?
Technically it's been checked when you've changed fuel filters but you might want to add that to your monthly list!
Right, I've had this truck 2 years and never drained the DFCM. I've only put 10k miles on it, so it hasn't needed fuel filters either. This is the first I've heard of weekly/monthly fuel maintenance.
I'm not doubting the sense in it, just wasn't aware. In the manual it says this should be drained upon getting the warning light that indicates 150ml water. (about 2/3 cup?)
I'm curious to see how much is there. It sounds like the system is designed to contain water up to the warning and not to exceed. Draining every week "just in case" seems a bit extreme, or am I missing something?
Old Feb 18, 2014 | 09:04 PM
  #44
KC8QVO's Avatar
KC8QVO
Just throwing this out there too - if you drive the truck rarely... you may want to be running some good fuel stabilizers/algae inhibitors. Diesel sitting for a long time can go bad. I've seen it happen with my backup 5gal can. Keeping all the parts running routinely is a good idea too = don't let the truck sit for weeks on end.
Check your diesel supplement manual for maintenance. I'd say most of us follow the "severe service" intervals = fuel filters every 15k, oil changes every 5k.
If you can, when you do get your fuel filters changed - either done yourself or dealer - grab a couple pictures of the DFCM filter and watch it come out of the truck. If you see any red/brown globs that look like grease or thick jello it is algae build-up, which in a way is good because the filter is doing its job, but not so good because you shouldn't have much, if any. One of my filter changes thus far had a few blobs of algae, but that's all I've seen so far.
Old Feb 18, 2014 | 09:09 PM
  #45
Bobbykjl's Avatar
Bobbykjl
Chris, I read the same as you in the diesel supplement owner's guide. From the manual it sounds like the WIF sensor is what you go by before you need to climb under your truck.
If you flip to page 74 towards the bottom of the page you'll see the "Check every month" section. There it says "Fuel filter/separator, drain if necessary (or if indicated by the message center)".
I'm not sure what "if necessary" means.
My guess for the reason guys are checking more often is for piece of mind and one more level of protection to avoid costly damage. Too costly to depend on one sensor.
