DFCM draining...
Old Feb 28, 2014 | 03:23 PM
  #181
XXLTexan's Avatar
XXLTexan
Originally Posted by EO2SeaBee
Was he trying to drain the DFCM? You should point out that its further back.
AAAAAAAHAHAHAHA!!!!!! Ahhhh...I needed that.
Old Feb 28, 2014 | 09:32 PM
  #182
wtrlogd's Avatar
wtrlogd
This thread has been very entertaining.
My question is whether anyone has ever found water has a result of one of these monthly draining rituals. I've yet to find any, which makes me wonder if it is being separated. I can remember back in the 80's when I'd drain till the color changed then close the valve.
Moot point these days. I just change the fuel filters every couple months and drain DFCM at oil changes, but then I've been driving an average of 10-12K a month.
Old Feb 28, 2014 | 09:35 PM
  #183
wtrlogd's Avatar
wtrlogd
Deer picture is great.
Another 4-5 hit just last night in northern Idaho on Hwy95
Old Mar 1, 2014 | 11:51 AM
  #184
rtazz17's Avatar
rtazz17
Why so many? The time of the yr or just overpopulating the area?
Old Mar 1, 2014 | 01:07 PM
  #185
wtrlogd's Avatar
wtrlogd
I believe so. There seems to be a lot more deer on road this time of the year.
That road is especially bad due to the amount of traffic and thus headlights coming at you, meaning you you can't use highbeams to spot them. I'd also contribute much of the blame to a lack of cleared area on the sides of the road.
Old Mar 1, 2014 | 06:30 PM
  #186
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
My Avoidance System..............
Old Mar 2, 2014 | 10:06 AM
  #187
Dim Sum's Avatar
Dim Sum
I don't that I need to drain the thing, but this new 2014 drains more fuel out of the yellow **** than it does out of the drain port. Fuel flows out of both, one resulting in your bottle filling and the other resulting in diesel all down your arm, shirt, pants, and whatever you touch trying to get the F out of there.
I think either something is wrong with my fuel drain or Ford has gooned it up between my 2011 and this 2014.
Old Mar 2, 2014 | 10:20 AM
  #188
TRENT310's Avatar
TRENT310
Just use a larger bottle that has a opening wide enough to go under the drain port and the **** at the same time... also check the O-ring is seated in the correct place on the yellow drain plug, occasionally it slips when you are unscrewing it... of course you can't easily check that without fully removing the drain plug which results in fuel flow.
Old Mar 2, 2014 | 11:35 AM
  #189
UGA33's Avatar
UGA33
I use a mason jar. Opening is large enough to catch the **** and the drain. If I open it too far, it will leak out of the ****. I can control that. It has a steady stream out of the drain right before it leaks out of the ****.
Old Mar 2, 2014 | 12:24 PM
  #190
Tim Young's Avatar
Tim Young
Same on mine, I almost always get fuel on my hand first. My truck is so low to the ground it is a pain in the ****.
Old Mar 2, 2014 | 02:28 PM
  #191
marchare011's Avatar
marchare011
I'm glad it's not just me Tim. I was starting to think my belly was getting too big.
I always drive my front tires up on 4x4's when I change my oil cuz my bucket won't fit otherwise.
Old Mar 2, 2014 | 04:48 PM
  #192
Chris Stewart's Avatar
Chris Stewart
First drain after 2 years and 10k miles. Nothing there. Better safe than sorry I guess.
Old Mar 2, 2014 | 05:14 PM
  #193
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
You are right........It is your beer belly......
Old Mar 2, 2014 | 05:16 PM
  #194
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
I thought diesel was Red colored..............
Old Mar 2, 2014 | 05:33 PM
  #195
marchare011
I'm inclined to agree with ya Roy.
