DFCM draining...
Old Feb 26, 2014 | 09:45 PM
  #151
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Originally Posted by Phil-turbodiesel
I can help Matt...It's because all people don't think or rationalize the same as you or I or the guy down the road. We have different experience and opinions. Been this way since the cave man. haaa haa
Great inventions, discoveries and breakthroughs didn't come from sheep (easy now...not calling anyone a sheep).
I'm glad there are people that ask questions. I'm an A&P mechanic and constantly update maintenance and operation manuals. The publications are intentionally not bound so we can remove and replace pages. Examples of updates are...
1. Procedure clarification or improvement
2. Addition of PM action and/or interval
3. Removal of PM (Many PM's were found to be unnecessary, performing them only caused parts fatigue).
4. Spelling and grammer
Nothing gets changed by following the herd. At this point I personally don't give a rats behind on who does what. My thoughts are on taking the gray out of the "semantics of a single sentence" especially
when that sentence is written by the OEM who decides who pays a potential $12K price tag.
I Follow OEM manuals religeously, Because of the dialogue in this thread and kper05 sparking the thought to question the interpretation of the manuel I am going to do a 180 and start draining my DFCM once a month unless I see an OEM clarification to do otherwise. .
Keep 'em flying
BTW: Those sheep.......ya might wanta keep them away from the folks in Texas........
Just saying........Ya never know.........
Old Feb 26, 2014 | 09:55 PM
  #152
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Originally Posted by kper05
I'm still clicking ignore on my calendar reminder from Sunday that it's time to drain. Why can't it do it itself? ROR.
Yours doesn't...
Put the key in the ignition......turn on, But do not start.
Turn the head lamps on then off 4 times in quick succession (max 6 seconds).
Then honk the horn for 2 seconds.
Get out of the truck........look underneath. Diesel is flowing out of the filter/water separator for 10 seconds.
Did you put the jar under the drain port prior to all the above.........
Ya gotta love smart azzes..........
Old Feb 27, 2014 | 04:07 AM
  #153
EO2SeaBee's Avatar
EO2SeaBee
Roy, I tried your suggestion and all that happened was my sunroof and rear window opened and closed a few times, but no hands-free draining of the DFCM. I must've gotten the sequence wrong.
Old Feb 27, 2014 | 06:09 AM
  #154
Jigger2020's Avatar
Jigger2020
Lets say you get your fuel at the same place all the time.....
You check for water 12 times in one yr & its fine , no water, I think its safe to safe to say you can go 2 or 3 months between drains, anyone agree????
Old Feb 27, 2014 | 06:17 AM
  #155
720Deere's Avatar
720Deere
I'll buy that and even admit to doing it! Still not the same as just waiting for the light of doom to appear.
Old Feb 27, 2014 | 07:33 AM
  #156
Javi1's Avatar
Javi1
Dang... I'm 65 with bad knees, bad back, bad shoulder plus I'm 100 lbs over weight and yet I'm not so lazy or so busy that I can't take 5 minutes once a month to crawl under my truck and drain the water filter... No wonder the other countries think Americans are all fat and lazy..
Old Feb 27, 2014 | 08:19 AM
  #157
Phil-turbodiesel's Avatar
Phil-turbodiesel
Originally Posted by 2piecespecial
So after all that, you see it my way. I'm glad I could help out another pack of the "Herd. My work here is done Lois!
Obviously, I'm not a member of the "Phil Herd."
touche'
Good stuff Larry.
Old Feb 27, 2014 | 08:40 AM
  #158
Phil-turbodiesel
It would be interesting to see if once a month, the water is so minimal you can't really see it, but three or four months you might see the little water bubbles appearing? an accumulation thing.
Of course even once a month doesn't help the one "bad fill". Then it's all about relying on the WIF to hopefully save our butts.
True Matt
...curious as to what your seeing in the jar when draining on some of your longer intervals?
Old Feb 27, 2014 | 09:18 AM
  #159
Phil-turbodiesel
Somebody get this man a lolly-pop! (just kidding Javi1, no ill intent)
I'm 100 lbs over weight ...
hmmmm
Old Feb 27, 2014 | 09:29 AM
  #160
Javi1's Avatar
Javi1
hmmmm
Yep... I'm fat but that doesn't mean I'm lazy I still work 50+ hours a week and do my own yard work. And as I said... I'm not so lazy or so busy that I need to forgo draining the water filter once a month..
BTW not having a working thyroid is a bitch...
Old Feb 27, 2014 | 09:45 AM
  #161
OutlawII's Avatar
OutlawII
This thread!! lol When im running hard in the summer i drain it weekly,i would also say it makes a difference if u let it sit overnight before draining lets the water accumualte in the bottom of the housing. This is what i have noticed in equipment at work i would assume it would apply to these trucks also,same basic filtering principle.
Old Feb 27, 2014 | 10:29 AM
  #162
elee3's Avatar
elee3
Can't do that, I'd run out of fire starter.
On a more serious note, when not traveling, I fill up once a week. My interval for checking/draining the filter should be different than someone who fills up more or less than I do per week or month. Using engine hours, gallons used or miles would be a much better maintenance interval than monthly.
Old Feb 27, 2014 | 10:35 AM
  #163
Phil-turbodiesel
No ill intent Javi1... got some med issues myself.
Somebody used the lolly pop ribbing on me awhile back when I was bragging about myself and I just had to use it
The thread kind of moved passed the "bitch, bitch, bitch" , "lazy or not" subject quite a few pages ago.
I'm not lazy either
Old Feb 27, 2014 | 10:57 AM
  #164
Bobbykjl's Avatar
Bobbykjl
Javi. sorry to hear about your medical issues but then you should know it doesn't make you lazy if you can't do something.
Early on in this thread, I posted about my 78 year old neighbor who has a 6.7L and finds it difficult to climb under his truck (two wheel drive with running boards). He has a host of medical issues that he doesn't "share". He's a proud man and only retired 3 years ago. The only complaint he has was the diesel running down his arm.
He tows a large 5th wheel (buying a Prius is not an option).
He now chooses to drain "once in awhile". He's not a lazy American.
Old Feb 27, 2014 | 11:10 AM
  #165
jd350b's Avatar
jd350b
phil-turbodiesel where are you getting these pictures! ILMAO
I'm not lazy either, I just don't want to break my nails! Just kidding.
Hey guys, is it ok to pour the fuel back in my tank? My uncle just tossed it on the ground.
Obviously if there is any water or dirt in it I won't but what's the best way to get rid of it? Put it in the garbage?
