cigarette lighter intermittent
Old Feb 2, 2014 | 05:14 PM
xaviar's Avatar
xaviar
I've noticed lately that when my phone is plugged into the cigarette lighter the charging light will go out and stay out. sometimes coming back on if I plug it in I've noticed it doesn't matter what cigarette lighter port I use either. I know to check the fuse but just looking for some other feedback. thanks in advance.
Old Feb 2, 2014 | 05:35 PM
jswartz84's Avatar
jswartz84
How does the charger work in other vehicles? Could be the charger.
Old Feb 2, 2014 | 08:20 PM
9228.bobcat's Avatar
9228.bobcat
X2 on the charger.
Old Feb 2, 2014 | 08:27 PM
Money-Pit's Avatar
Money-Pit
X3 charger
Old Feb 2, 2014 | 08:55 PM
xaviar's Avatar
xaviar
I'll check the charger too. Thx.
Old Feb 2, 2014 | 10:17 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Check the wiring hooked to it. (the lighter on the back side) It doesn't stay connected very well.
Just so you know, the lighter is on the same fuse as the OBD2 port. If you have it, suggest you use the power port instead.
Old Feb 3, 2014 | 05:52 AM
npccpartsman's Avatar
npccpartsman
I would say if it's not staying on in either port it's the charger. The ports are on separate fuses.
Old Feb 3, 2014 | 10:00 PM
xaviar's Avatar
xaviar
Ok. Here's the verdict. When charging light goes out it still charges the phone for about 2 minutes and stops. After a few minutes the light will sometimes come back on and start changing the phone again. So, charger is defecttive. Thank you all.
Old Feb 3, 2014 | 10:18 PM
04badford's Avatar
04badford
my charger does this too ,I think the coiled wire pulls it out just enough to disconnect. I just reach down and pop it back in when it beeps at me. Try putting your phone in the little cubby and not inbetween the seat and console where the wire is stretched.
watercamper
Mar 2, 2015 08:23 AM
Boston Mike
6.7L Power Stroke Diesel
May 1, 2014 06:54 PM
hifiman
Sep 16, 2010 07:54 PM
gurns08
1997 - 2003 F150
Mar 25, 2010 02:27 AM
donaldm
2004 - 2008 F150
Oct 28, 2009 10:26 AM
