Fuse question
Old May 1, 2014 | 02:42 PM
Boston Mike's Avatar
Boston Mike
Fuse question
I'll preface by saying, my technical know how ends with swapping out lights. I'm sure this is an easy fix, but not sure where to look first. I recently got a pair of smoked out taillights and 3rd brake light and installed the tails..................easy job. Finally climbed up on the back to swap out the 3rd.............lights worked before I disconnected. Connected the new one, no go, so figured, I bet bulbs are out. Plugged original back in, no lights. Figuring I tripped a fuse somewhere.................anyone good with finding the right fuse?
Old May 1, 2014 | 02:54 PM
SavageNFS's Avatar
SavageNFS
If it's a Recon or similar, the new light plugs in where the former bulb plugged in. Be sure the wire contacts are straight in the new light plug and making contact with the bulb harness or the light won't work. Get some dielectric grease and lube the connection for a plug it and forget about it for a long time install.
Old May 1, 2014 | 02:56 PM
Boston Mike
No, it's an OEM 3rd light that was smoked. I've used this guy on prior cars, so I knew his work. So should have been a simple unplug, plug procedure.
Old May 1, 2014 | 06:28 PM
Dakster's Avatar
Dakster
Year and model will help me, help you... In any case, in the manual online or in your glove box it will tell you what fuse and where it is located.
Sounds like you did blow fuse... I've done that going into the light when it was hot and just touching the + to ground. Since you are outside you don't even hear the fuse go "click".
Old May 1, 2014 | 06:41 PM
Boston Mike
Now here's the oddest thing. So, I did the swap last night. Knew I had a problem this am when it was still doing it. Came out of work today and lo and behold it was working. I must have a had a loose connection or something. Still seems odd though......
Boston Mike
Ps, it's a 2012 CCSB Lariat
Old May 1, 2014 | 06:54 PM
Dakster's Avatar
Dakster
No need to locate a fuse then.
Might want to spray or put dielectric grease on the contacts and make sure the wires are not caught or kinked.
HRTKD
All Things Towing
18
Apr 20, 2017 05:30 PM
salf100
Jan 27, 2014 05:11 PM
TXtinct
Oct 17, 2012 10:01 AM
axlrose
Electrical Systems/Wiring
Nov 11, 2003 02:57 PM
cbeaur
May 9, 2003 03:54 PM
