Causes for idle only
Old Feb 3, 2014 | 08:26 PM
acf6's Avatar
acf6
Basically what my title says...what causes a 6.0L to go into idle-only operation? I know the throttle pedal can do it if all 3 sensors fail, but what else is there?
Old Feb 3, 2014 | 08:34 PM
78fordman's Avatar
78fordman
Loss of vref to the pedal assembly. I would verify with a dom actual pcm input from the pedal assembly as close to the pcm as possible.
Sent from my leash using IB AutoGroup
Old Feb 3, 2014 | 08:35 PM
acf6's Avatar
acf6
dom ?
Old Feb 3, 2014 | 08:40 PM
Money-Pit's Avatar
Money-Pit
It's gotta be Dominatrix or digital ohm meter.
Old Feb 3, 2014 | 08:49 PM
78fordman's Avatar
78fordman
A simple mutimeter. Back probe it and check the circuit with it plugged into the pcm. A bad connection or broken wire may mask it's self without any load on it. Kinda like a garden hose with a valve on the far end, crack the hose bib wait a minute and you will have full pressure until you open the far end and it will drop to near nothing.
Old Feb 3, 2014 | 10:39 PM
04badford's Avatar
04badford
Originally Posted by acf6
dom ?
TATS right, Snuggy worm. sorry Dom I couldent mis the Chance
TPS (throttle position sensor), Defective EGR, stuck turbo vein, VGT , open short in wire some where to name a few, did you take a look at the Vid I sent ( other thread )?
Old Feb 3, 2014 | 10:54 PM
BLADE35's Avatar
BLADE35
Originally Posted by Money-Pit
It's gotta be Dominatrix .
Yes Hands down the best way to deal with it
Old Feb 3, 2014 | 10:56 PM
BLADE35's Avatar
BLADE35
Jeez Miles truck wont give you any Breaks???
ICP will do it too
FICM
Battery or Alternator so Voltage problems
EGR Maybe
Corey Boucher
Dec 21, 2018 07:41 AM
jstihl
Dec 23, 2017 08:18 PM
Bertelrud
Jun 7, 2009 02:25 PM
GreatWhite99
Feb 18, 2009 06:17 PM
Gobstopper909
Aug 19, 2008 11:08 PM
