Sponsored by: Auxito
Accessory plug not working
Old Mar 21, 2010 | 12:35 AM
gurns08's Avatar
gurns08
Hello everyone, I am looking for some help here. I own a 2002 f-150 supercrew 4wd 4.6 liter. The cigarette lighter/accessory plugs in the dash are not functional. I have checked all the fuses and none are blown. If anyone has any ideas or solutions I would appreciate it.
Old Mar 21, 2010 | 09:27 PM
darkmage55's Avatar
darkmage55
When i installed my CB radio, i put it in the accessory plug and accidentally shorted out some wires on my CB and it blew the fuse. Check your fuse bos under the hood, near the next to the brake master cylinder and the air filter housing. Double check the fuses, just in case. If your not sure about the fuse, just throw in a new one. Sometimes helps to try.
Old Mar 24, 2010 | 09:45 PM
Podaso's Avatar
Podaso
Blown fuse is the only thing I can think of...
Old Mar 25, 2010 | 02:27 AM
Bluegrass 7's Avatar
Bluegrass 7
I don't know if you have a blown fuse but take a good look into the outlets.
The ligher socket is not made for use as an external power source. It's different.
The fuses are in the engine bay box. Keep track of where you pull them from.
It's easy to tell if one is blown by looking at it's element compaired to a good fuse.
The CB plug may have a fuse in it's body.
