HPOP
Old Jan 10, 2014 | 04:45 PM
Jerry Chaney's Avatar
Jerry Chaney
HPOP
Just pulled my HPOP 7.3 the o-rings are definitely shot. I was wondering if one could tell if it was a bad pump just by looking at it
and why can't I post attachments
Old Jan 10, 2014 | 04:58 PM
Tom's Avatar
Tom
See below on how to post pics:
Old Jan 10, 2014 | 05:03 PM
Layson's Avatar
Layson
Post up over in the 7.3 Powerstroke area. You will get a lot of help their!
Tom's Avatar
Tom
I can help out with that one.
Moved to the 7.3L forum!
Old Jan 10, 2014 | 05:34 PM
Jerry Chaney
thought I was thanks
Old Jan 10, 2014 | 10:35 PM
Tailgate77478's Avatar
Tailgate77478
Just because o-rings are bad doesn't mean the pump is bad. Why did you pull it in the first place? If because of a huge oil leak / dump, then check the HPOP hoses.
There is a "non serviceable plug" on it that has a tendency to leak. But it IS serviceable. https://www.ford-trucks.com/forums/6...your-hpop.html Also, on Bob's site for the non-serviceable plug repair kit, there is a downloadable PDF: http://www.dieselorings.com/servicea...hpop-plug.html
Old Jan 10, 2014 | 11:15 PM
Jerry Chaney
I was going thru oil like crazy, 5 quarts in 10 miles. Replaced Oil Cooler last week, now fixing leaks on HPOP, one was fuel line, and the other was the non-serviceable plug.
Old Jan 10, 2014 | 11:19 PM
Jerry Chaney
Old Jan 11, 2014 | 03:17 AM
Tugly's Avatar
Tugly
Did that O-ring come off the IPR in the picture? I see the small one is shot as well.
Old Jan 11, 2014 | 09:03 AM
Jerry Chaney
IPR
yes. that 0-ring is off my IPR, I have rebuild kit coming today, I hope. Could my massive oil leak have come from there?
Old Jan 11, 2014 | 11:25 AM
Tailgate77478
I am no expert, because the volume you are talking about is quite heavy. However, if that o-ring was busted, you can see the channel cut in the threads would allow oil to shoot right through there under high pressure, and with a cut/busted o-ring there wouldn't be too much to stop the oil from coming out. So I suppose it is possible that was your culprit.
Old Jan 11, 2014 | 12:03 PM
CGMKCM's Avatar
CGMKCM
My theory is the IPR was not tight in the pump and backed off which allowed oil pressure to cut the o-ring. Yes it would be a massive leak. Check the unserviceable plug, based on the picture, it looks like it was leaking also. For that plug to leak it would also have to become loose and oil blow by the o-ring.
Old Jan 11, 2014 | 08:27 PM
HD Rider's Avatar
HD Rider
Was all that oil landing on the ground or disappearing somewhere else?
The reason I ask is because a blown injector oring will dump oil into your fuel.
Old Jan 11, 2014 | 08:51 PM
Jerry Chaney
not very much oil on ground, but I do have oil in my fuel. I was hoping to see something distinctive on the o-rings, they defin. look worn out, but nothing obvious. going to pull the other bank tomorrow. thanks everyone for your feedback, love this site.
Dylan Hengeseteg
Mar 8, 2017 03:45 PM
LCMB
Oct 17, 2016 10:40 AM
jbravata2
1983 - 2012 Ranger & B-Series
28
Feb 22, 2013 01:43 PM
FloridaF250
May 8, 2008 07:01 PM
