Another CPS failure?
Old Jan 11, 2014 | 11:10 AM
cabloom300's Avatar
cabloom300
I had just replaced my CPS about 2-3 weeks ago after my stock one failed. I replaced it with the grey OEM one. All was well with no issues. Today I was driving in the rain and all the sudden it cut out. I went for another mile to my destination and it was ok. I'm going to rerun home and il see if it does it again. This sounds like another CPS. Why do these things fail? How can't ford fix this problem. Thanks
Old Jan 11, 2014 | 11:22 AM
Tact's Avatar
Tact
Try to relocate your ground for the wiper motor. I've also heard that the ICP may cause the interference as well.
Old Jan 11, 2014 | 12:53 PM
crop harvester's Avatar
crop harvester
check the plugin at the cps & wiring for places it could rub through,as well.
Old Jan 11, 2014 | 08:25 PM
Brother Les's Avatar
Brother Les
The 'rain' is your flag. it is not the CPS. Mine did this several time when I drove in the rain and hit a puddle. Water sprayed up and hit the CPS and it would kill the truck as if it was shut of at the key. I ended up taking it off and sealing the CPS where it goes in the block and putting sealant where it plugs in. No problems since.... reseal the CPS and plug and it should be just fine.
Old Jan 11, 2014 | 08:32 PM
Pikachu's Avatar
Pikachu
Make sure the connector hasn't lost the silicone seal. I've found they have a tendency to slide off sometimes when the connector is removed.
Old Jan 11, 2014 | 10:43 PM
cabloom300's Avatar
cabloom300
Alright.. On my trip home it didnt do it so im hoping that it was a one shot deal but i will look into sealing it better as well
Jaaaaaaackman
Aug 10, 2012 04:21 AM
lifted77f250
Aug 27, 2008 11:48 PM
99powerstrokeSD
Apr 11, 2007 06:43 AM
Clint Knotts
Jul 9, 2006 12:03 AM
