Tweeter placement
Old Jan 9, 2014 | 10:54 PM
Vince79vette's Avatar
Vince79vette
Tweeter placement
Just picked up a set of tantric hd comps and where are u all having luck with where the tweeters are
Old Jan 10, 2014 | 12:47 AM
Technologiq's Avatar
Technologiq
Mine are installed in the door sail panels and sound great!
Old Jan 10, 2014 | 02:09 AM
GermanMike's Avatar
GermanMike
I have them costum laminated into the black plastic corners of the mirrors.
Slightly angled towards my head and into the middle.
That sounds awesome wide and harmonic........just my 2cents
Old Jan 10, 2014 | 07:24 AM
william_04_x's Avatar
william_04_x
The black plastic inside mirror covers are the sail the sail panels, Mike. That's a great location.
At the front of the top of the dash, firing upward is also very good. Tweets reflect off the windshield very well.
Old Jan 10, 2014 | 07:54 AM
johntpr's Avatar
johntpr
https://www.ford-trucks.com/forums/6...placement.html
Old Jan 10, 2014 | 07:57 AM
johntpr's Avatar
johntpr
I used 2008 and up OE Tweeter sail panels and put better than OE tweeters in there.
Here is some info from another site:
Stereo Time - Ford Powerstroke Diesel Forum
Old Jan 10, 2014 | 09:43 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
How do you wire tweeters? Just split the front door wiring or thier own dedicated wire from the HU?
My Caddy has the Bose system and I'm seriously jealous of it and need a better setup in my X. I'm going to put tweeters in the A pillar trim under grab handle
Old Jan 10, 2014 | 10:21 AM
GermanMike's Avatar
GermanMike
Damned.....now im blushing!
I need to improve my English....fast.....
because I hate it to get caught with my pink string pantys down.
Thanks for your correction anyway. Thats the only way I will learn it.
Old Jan 10, 2014 | 11:55 AM
Vince79vette
The black plastic inside mirror covers are the sail the sail panels, Mike. That's a great location. At the front of the top of the dash, firing upward is also very good. Tweets reflect off the windshield very well.
That is what I am thinking the sails.
Old Jan 10, 2014 | 11:56 AM
Vince79vette
Originally Posted by Tylus
How do you wire tweeters? Just split the front door wiring or thier own dedicated wire from the HU? My Caddy has the Bose system and I'm seriously jealous of it and need a better setup in my X. I'm going to put tweeters in the A pillar trim under grab handle
U have to have a crossover on them. U can buy them cheap online just what hz u want the cut to. Than it will separate the hz to the tweeter and mid
Old Jan 10, 2014 | 12:12 PM
Vince79vette
Thanks man
Old Jan 10, 2014 | 01:02 PM
Technologiq
Here are the pods on eBay:
http://www.ebay.com/itm/2008-Ford-F350-Left-and-right-door-panel-upper-bezel-with-tweeter-speaker-/121241218745?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c3a8a2eb9&vxp=mtr
Here's how I did mine (I've been really happy with this)
Old Jan 10, 2014 | 01:21 PM
GermanMike's Avatar
GermanMike
You cant get answer in generell. I'll try to explain it and please be patient with me and my humbling English.
1st. The most usual way.
You buy a real 2 way system and since you want to locate them at different places youll need NOT a CoAxial-System (Thats those one part chassis with a tweeter integrated).
Real 2ways (Passive) have always a little device which split the frequencies for you. So you have two wires (-/+) coming from your HU or the Amplifier into this device and from there you have 2x 2several cables which feed your Midbass (for example the door) and the other pair feed the tweeter in the SAILS for example.
If you want to build up a real HiEnd Stereo you have to buy a active 2way system. This system has more power and can be better adjusted to your needs or your car. The difference is that there is no device which split the frequencies, and you go directly with seperate cables from your amplifier to the midass and the tweeter. The adjustments has to be make at your amplifier or DSP device.
guypwill
Mar 1, 2018 03:06 PM
AMGrulz
Sep 18, 2015 08:20 PM
Plain Jane
Apr 25, 2012 02:57 AM
casanezo
Feb 19, 2010 01:24 PM
1982fordf100
Nov 29, 2004 12:49 PM
