05 Tranny Question
Old Dec 30, 2013 | 12:25 PM
Casepuller's Avatar
Casepuller
05 Tranny Question
I flushed my transmission and now it acts like it double shifts when shifting from 2nd to 3rd.Could it be a solenoid??
Thanks
Toby
Old Dec 30, 2013 | 12:53 PM
69cj's Avatar
69cj
How did you flush it and what fluids did you use?
Old Dec 30, 2013 | 01:09 PM
Casepuller's Avatar
Casepuller
I flushed it with a tranny flush machine and used mercon sp fluid.
Old Dec 30, 2013 | 01:20 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Do a Trans relearn before freaking out too much.
Josh
Old Dec 30, 2013 | 02:00 PM
Casepuller's Avatar
Casepuller
I will try that Thanks
Toby
Old Dec 31, 2013 | 06:36 AM
Casepuller's Avatar
Casepuller
I did the trans relearn and still shifting funky and getting worse. Was the flush a bad idea?
Old Dec 31, 2013 | 07:05 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Did you do the Torqshift relearn? Or did you just drive the truck around?
Old Dec 31, 2013 | 08:03 AM
Casepuller's Avatar
Casepuller
I did the Torqshift relearn.
Old Dec 31, 2013 | 08:06 AM
npccpartsman's Avatar
npccpartsman
Did you do the flush as a normal maintenance routine or because your transmission was acting up to start with?
You might want to find a high end scan tool to scan the truck with to see if it pops a transmission code.
Old Dec 31, 2013 | 08:26 AM
69cj's Avatar
69cj
Where did you get a flush machine and does it pre-heat the fluid?
Old Dec 31, 2013 | 09:01 AM
Toreador_Diesel
Good question...
Old Dec 31, 2013 | 12:45 PM
Casepuller's Avatar
Casepuller
I just bought the truck so i flushed the tranny so i knew when it was done. A friend of mine works at a ford dealership and we did it there with their machine.It idled for about ten minutes and then we flushed it.
Old Dec 31, 2013 | 01:19 PM
69cj's Avatar
69cj
Idling for 10 minutes does not open the internal tranny t-stat for full flow and if the fluid wasn't pre-heated it then will not open the t-stat. I wasn't there but I highly doubt that you got a full tranny flush. Back to Tim's ?, was the tranny having symptoms prior to the flush?
Old Dec 31, 2013 | 02:01 PM
Casepuller's Avatar
Casepuller
According to the machine it took out 19 quarts and put in 19 quarts and fluid level was fine.Im not sure if it was shifting ok before i bought it but when i test drove it before i bought it, it shifted ok to me.I just got home and i checked the fluid level and its full but it already dark.
Old Dec 31, 2013 | 02:40 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Idling for 10 minutes usually won't get the trans anywhere near warm enough to open the thermostat.
Was it a heated flush machine? Even a non-heated machine can put 19 quarts into the trans and take out 19 quarts. If it isn't a heated machine most of the quarts coming out are the same ones that the machine is putting in instead of exchanging old fluid for new fluid.
myblkex
Sep 5, 2010 07:36 AM
CoogFx4
Jun 20, 2009 12:23 PM
silverxlt
Feb 4, 2005 07:44 AM
jon brown
Jan 22, 2005 01:18 PM
14u2nv
Jan 18, 2005 09:34 AM
