How to remove dash knobs on my 59?
Old Dec 21, 2013 | 09:25 PM
Vsanzbajo's Avatar
Vsanzbajo
How to remove dash ***** on my 59?
I am trying to replace the old broken *****, but they are not budging. I was trying the choke ****, the new one looks like a screw one but the old one is not moving, any advice?
Thanks for all the help.I am really enjoying my new truck.
Old Dec 21, 2013 | 11:11 PM
F250racer's Avatar
F250racer
Most of them are removed by loosening a small setscrew in the back of the ****. I believe the choke unscrews from the behind the dash and the whole ****/choke cable assembly pulls back out through the dash(if I remember correctly). The headlight know is removed by pushing a button/tab on the bottom of the switch(**** and shaft remove as one piece).
Old Dec 21, 2013 | 11:14 PM
Vsanzbajo's Avatar
Vsanzbajo
To do the choke you need to remove the all thing? I just want to replace the white ****.
Old Dec 21, 2013 | 11:17 PM
F250racer's Avatar
F250racer
That's how I remember it when i did mine. Check to see if there is a small setscrew towards the back of the ****. If not then the know doesn't separate from the shaft.
Old Dec 22, 2013 | 02:28 AM
59 shorty's Avatar
59 shorty
what F250racer said. original choke and air vent cables and ***** are a single unit. Mine were worn and nicked up from age. I smoothed them up with sand paper and resprayed all with the same color along with the steering wheel so everything matches.
Old Dec 22, 2013 | 07:52 AM
Damifiknow's Avatar
Damifiknow
I replaced my broken choke cable and the new was a screw on type while the old was molded into the metal rod that attached to the cable. If that makes sense.
Old Dec 22, 2013 | 11:01 AM
Vsanzbajo's Avatar
Vsanzbajo
So I have the screw **** that I bought, Is there anyway to just swap the choke **** without getting the whole unit?
Old Dec 22, 2013 | 12:04 PM
Danleig's Avatar
Danleig
You could always just take a torch to the old **** and carefully melt it off.
Old Dec 22, 2013 | 01:20 PM
59 shorty's Avatar
59 shorty
might also try heating the old ****/cable in a pan of hot water just don,t use mama,s good pans!!
Mearntain
13
Jul 8, 2019 12:56 PM
3twinridges
Aug 28, 2017 09:41 PM
rnelson664
Jan 29, 2015 05:45 PM
santi2322
Jan 29, 2009 12:46 PM
erinaldi
Nov 26, 2004 04:24 PM
