Firegod - Thanks. But I'm an engineer and not an artist, so I'm looking for other's input as just about anybody has more creativity than I do.
Jim - You must have the same cell company that Chris and David do. Neither had coverage at my house.
Anyway, I think I'm with you part way, but don't understand everything. By "stripe" you mean the recessed line? But, I'm lost on "ensuing points" and "the way the stripes end", although the latter may be something about how or where they stop. Anyway, please elaborate?
Sprint.
When I can afford a GSM phone I think I'll be going with T-Mobile.
Look at the radius at the end of the border.
Look at how you would be left with two 'points' if you opened the chamfer up.
Imagine a similar radius to the border to those two points.
Sprint.
Look at how you would be left with two 'points' if you opened it up.
Imagine a similar radius to the border to those points.
I can't explain it any better.
T-Mobile is what David and Chris have, if I remember correctly.
By the "radius at the end of the border", do you mean these?
If not, please try again as I'm dense but interested. If so, then help me understand "if you opened it up". Opened what up? I just am not seeing the "points".
Yes.
So make the chamfer as wide as that border.
A colored ring (3/16"?) wide around that shiny bolt head.
Can you scale a circle around the bolt head, with a diameter that mimics the width of that border line???
If you do that, it will spill out to the side, and the black of the side could flow around the same radius you have circled, into the chamfered area surrounding the bolt head.
Instead of coming to a point on each side.
Not exactly what I was thinking about, but it looks good!
Do you see how the aluminum comes to a point at each side above the bolt head?
What if you blunted that point so it had the same radius as the end of the line that you circled in yellow?
