Swamps IDM verse 120 IDM
An IDM 140 doesn't change SOI, nor does it make an appreciable increase in power. The only real benefits of reducing the "lag" between the SOI command and the physical implementation of it are reduced start time and a throttle pedal that is a little more responsive. Neither of which can be accomplished through tuning.
Also, tuning can accomplish both "reduced start time and a throttle pedal that is a little more responsive". A reason people choose to either stay or go away from certain tuning companies is one of those. Also, the start time can be increased, decreased, made more "authoritative", or "soft"/"gentle" in the tuning at any time. Most folks don't change the second aspect though...I like to make my 7.3Ls start like 6.0Ls.
Now, is there something to a 140-ish volt IDM? Of course, there HAS to be. It causes a reduced armature-to-coil "suction" time because of the greater magnetic field that is produced. There's no denying that and I'm glad that you love yours. I'm neither a fan or not a fan of it. If I needed to buy another IDM, I'd probably look into one. However, until that time comes, I'm not spending my money just to try it.
Using very careful wording here to clarify my position:
I raise questions to consider openly and invite feedback, I do not "suggest" anything either way. I only say I have more experience with solenoids than one would normally imagine (just one device I work with on a daily basis has 640 solenoids... and I oversee many of such devices). Many of us are familiar with the drawbacks of strengthening one thing, then discovering it stresses something else. The solenoids will very likely be just fine with the upgraded IDM, but we have enough problems with wiring harnesses without upping the amps. Stinky's doing fine without this mod, so I opt out.
I don't dissuade other from trying the mod, I just raise the questions that really should be brought up when considering it.
You suggest that longevity can or will be compromised. That may be true, but mine has been running without issue since I did the mod in the spring of 08. Which means that nearly half of the 285,000 on the IDM are modded miles.
Say what you will, but I'm one of those guys that thinks this mod is a no brainer and everyone should do it.
Now as far as the statement you made that I highlighted you pointed out that the "phyical implementation" is where things get started. So it makes me think about what parts do what and when so correct me if I am wrong. First foot on the skinny pedal then the TPS sends a signal to the pcm which then sends a signal to the IDM. Then from the IDM to the injector solenoid.
Now I read on an other forum about blueprinting the throttle pedal assembly. Which makes me want to check, replace or dail in my TPS at the same time that I do the IDM. Since if the TPS doesn't give the pcm the correct signal it is looking for it too can throw things off.
Too much timing makes things go "BooM" !!!!!
SkySkiJason
03-20-2012 10:55 PM
Oversize
05-03-2010 10:59 PM
SF-ESS
11-27-2009 08:11 AM
